 Post subject: Samsung HD103sj not spinning or making any noise.
PostPosted: May 9th, 2012, 10:15
My samsung hd103sj died after a hard reset of my computer. I have two other hard drives in the PC and they both are working correctly, the samsung fails to spin and causes errors if it is plugged in when booting.
I have tested and removed the TVS on the PCB and jumped the fuse. Still no results. Right now I'm looking to get a new PCB for this drive. I plan on performing the chip swap as well, my only concern is PCB compatiblity. I see model numbers for PCB's such as BF41-00314A 00 S3M Rev. 03 R00 and BF41-00303A 00. I'm just not sure which ones should be compatible.
I'll post some pictures of my hard drive for reference
http://i.imgur.com/eE289.jpg
http://i.imgur.com/ttyAA.jpg
http://i.imgur.com/jFV5v.jpg
 Post subject: Re: Samsung HD103sj not spinning or making any noise.
PostPosted: May 14th, 2012, 7:01
Did you check all the TVS's ??
PostPosted: May 14th, 2012, 10:49
I'm guess yes by there comment in the original post
Loki
PostPosted: May 14th, 2012, 11:32
Grammatically that means he tested and removed 1 TVS. Board looks like it has several TVS's. A matter of semantics perhaps. But I'd be sure to check them all.
PostPosted: May 14th, 2012, 12:26
"Jumped the fuse"
Does that mean that you bridged the connection?
PostPosted: May 14th, 2012, 15:01
There are several diodes but only two TVS diodes.
@rayf937, the following PCB supplier offers a free "ROM" transfer service:
http://www.donordrives.com/services
Check this guide for PCB matching:
http://www.donordrives.com/blog/pcbswapguide
Users browsing this forum: gold6565, Majestic-12 [Bot] and 109 guests
