 Post subject: WD320BMVU-1104S0 help with PCB
PostPosted: May 21st, 2012, 3:52
i have this drive and has a pcb with USB conector. in order to plug it with sata i connect it with wires to another pcb. I don't know which resistors i have to remove from the original pcb in order to play. i have a attached o photo of the original PCB.
Thank you
WP_000112.rar [1.4 MiB]
Downloaded 370 times
 Post subject: Re: WD320BMVU-1104S0 help with PCB
PostPosted: May 21st, 2012, 4:08
Thank you
well by doing so without proper tools you will face the enc. issue
i guess this subject been discussed many many times here and you may refer to anyone of those
PostPosted: May 21st, 2012, 4:35
You need to remove 4 capacitors, not resistors. They are not the same thing.
http://en.wikipedia.org/wiki/Resistor
http://en.wikipedia.org/wiki/Capacitor
PostPosted: May 22nd, 2012, 3:15
@fzabkar sorry for the resistor, you are right. In Greece we have a bad habit naming things being comfortable with! :) . A friend at the forum helped me once giving me a photo of which capacitors have to be removed, but at a USB 3.0 PCB. i tried to find a photo with this PCB but couldn't find one.
Users browsing this forum: No registered users and 64 guests
