Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD10EADS smooth chip is fired
PostPosted: May 27th, 2012, 11:39
unknown wrote:
According to the motor chip condition, there's high possibility that the preamp is damaged as well.
Replace the PCB, transfer the original ROM and I wish you luck ( which you will need it )
Good luck.
Just for araifa info:
If you swap over the ROM from the patient PCB to the compatible donor PCB. Then cover the pre amp connections with a piece of card & then attach that to the patient hdd housing the drive should spin up - which is good, disconnect power & PCB, remove the card covering the pre amp connections & then re-attach the PCB. If it then doesnt spin up then pre amp is damaged & could have possibly have damaged your donor PCB, thats the risk you have to decide to take. If the later happens then sorry no DIY as the internal heads & pre amp will need to be swapped by a pro.
Loki
PostPosted: May 27th, 2012, 14:07
The OP has already determined that the preamp is not shorted. That was the purpose of the resistance tests.
PostPosted: May 27th, 2012, 14:17
NOT SHORTED doesn't mean IT WORKS.
Nevertheless if it is SHORTED it likely can fry a new PCB.
Users browsing this forum: No registered users and 53 guests
