 Post subject: ST31500541AS LED Error , Pins to Short
PostPosted: May 30th, 2012, 3:21
I have ST31500541AS , I need the pins to short to solve the Led error,
 Post subject: Re: ST31500541AS LED Error , Pins to Short
PostPosted: May 30th, 2012, 3:31
Is terminal access locked? Which LED error are you getting?
If you spend a bit of time studying the PCB it should be relatively easy to find the shorting points :)
Perhaps give some more detail on the terminal output.
Data Recovery Cape Town
PostPosted: May 30th, 2012, 3:37
The PCB is blocked, no output at all, spinning, no clicking, making the lovely trrrrrrr sound and then keeps spinning. BSY only is on. Could not access the terminal.
Thank you
PostPosted: May 30th, 2012, 3:58
PostPosted: May 30th, 2012, 4:00
You can always try the "card" method if you can't find the pins, though it's worth reading around a bit so you can learn how to find them yourself which will help you when new PCBs come out.
But… I believe these are the two you need:
PostPosted: May 30th, 2012, 4:17
Thank You for Your Kind. Appreciate your Help.
PostPosted: May 30th, 2012, 4:20
You're welcome! Best luck with your recovery!!
PostPosted: May 30th, 2012, 4:55
Something doesn't look right with the ROM chip. Excess solder, burn marks on pcb, sticker over what looks like melted plastic, white corrosion looking stuff around it...
PostPosted: May 30th, 2012, 4:57
No, we swapped the rom to another pcb to check only, it is alright, thank you. This resulted from soldering the rom
PostPosted: May 30th, 2012, 5:00
Id fire the person that transferred the ROM....
PostPosted: May 30th, 2012, 5:03
:D :D :D
Users browsing this forum: rasz_pl and 51 guests
