This is what I noted right away, and it's a tedious thing to point everything out. The fake label is wrong and full of tiny mistakes. Basically we're looking at spelling and spacing mistakes.
1- label edge and cut is wrong, curve not smooth either..
2- left label position off, covering indented mark if there is a mark there, should have more marks too
3- serial number, vertical spacing, ":" position
4- spacing error, vertical, and 16MB spacing
5- spacing error, mostly vertical
6- spacing error
7- spacing error and poor quality connector graphic
8- oversaturated sata/jumper graphic
9- more spacing errors, positioning of ":" and "M" in relation to barcode and sata graphic
10- seal = sesl ? spelling error, vertical spacing between 2 lines
11- vertical spacing
12- LBA, most likely should be here and not by 14, due to printer limitation see 10, 11
13- DATE, WWN justification, vertical cspacing consistency
14- more spacing errors, again with ":" and font proportionality, U.S. LBA vertical error
15- "Prod uct" vs "Product", also vertical space problem
16- Canada ICES & NMB position all wrong, ROHS appears almost subscript
17- ZEP vs A and justification
18- missing code array (I call them dotboxes)
19- what is this series of labels? Is it covering up something?
20- position of label against indented mark
21- note the sharper curve in the label here
22- the white arrow in WD is too thin, spacing between the stylized WD is too narrow
23- edge is not perfectly straight, note the waviness
24- stamped marking, not deep enough, grain of metal wrong.
25- edge too sharp and wrong cut size (for this model)
26- what's this circular mark?
27- off center screw cover
28- 2 "cut off areas" were ripped by stress and not a clean cut, too many of these
29- screwdriver markings
30- wrong screw (for this model drive)
31- label thickness appears wrong
32- P/N vs R/N
33- poor quality graphic
