 Post subject: seagate barracuda 7200.11 failure
PostPosted: May 29th, 2012, 14:29
Mine died last week-end.
Spinning, but not recognized by bios.
No clicks.
2nd drive -no OS but valuable data (lots of music)
ST3500320AS - 500 Gb -OEM
firmware SD15
date code 09133
site code KRATSG
country: Belgium
Have read some earlier threads from 2009/2010
Doesn't look very encouraging.
Help wanted, please :(
 Post subject: Re: seagate barracuda 7200.11 failure
PostPosted: May 29th, 2012, 15:29
It is most likely a very common firmware bug.
Many people have fixed it DIY, but to be safe it would be best to have a professional do it.
If you accept the risks of DIY there are many how-to articles around. Otherwise, a pro should be able to fix this for a minimal charge.
Data Recovery Cape Town
PostPosted: May 29th, 2012, 15:46
Normally SD15 is the FW bug and it should not be too hard to make your terminal cable and follow the instructions on this one. They are all over the web and this forum.
But also agree wtih Nick_CT that is is a DIY but in doing so there are a lot of risks involved in this one and some have killed or bricked their drives doing this. But DIY is possible if you want to accept the risks in this one
Iorana Haraharaini
PostPosted: May 29th, 2012, 16:07
You both forgot one thing that must be added to the "caveat" : the "internet fix" one-fits-all CAN be potentially dangerous for data because of how it is. So even the successful DIY CAN lead to potential partial loss of data.
PostPosted: May 29th, 2012, 16:21
I don't know about others, but I still get a lot of this series of drive in, but hardly any of them have a firmware bug any more. Most are bad sectors and/or failing heads.
PostPosted: May 29th, 2012, 16:46
I have seen very few, actually. Exactly like failed TVS.
PostPosted: May 29th, 2012, 17:08
We get more seized than anything else now, very few with "the" fw issue.
PostPosted: May 30th, 2012, 1:17
This month I've had 3 SD15s:
1x BSY bug
1x Weak head
1x Seized
So there are still some BSYs floating around out there, albeit very few. Maybe the OP is lucky.
PostPosted: May 30th, 2012, 1:51
Agree, FW problems more rare lately. Last two ST3500320AS w/ SD15 we got had bad heads.
PostPosted: May 30th, 2012, 5:02
Post a terminal log.
PostPosted: May 30th, 2012, 13:14
I'm still looking at my options.
Ironically, this originally was a backup-drive.
Which was later half filled with music, while waiting for HD's to become affordable again :(
PostPosted: June 25th, 2012, 9:05
Update:
I decided to contact Seagate.
After some mails they finally agreed to repair it for free, if it was the dreaded SD 15 firmware issue.
Today it was delivered, free of charge.
Thank you Seagate!
Users browsing this forum: No registered users and 221 guests
