 Post subject: WD3200BEVT locked? frozen? dead? wth?
PostPosted: May 31st, 2012, 4:54
Hey guys
yesterday I tried to update the firmware of my WD drive in order to use it with my Xbox. For some reason the updated failed. So now it seems I have very limited access to the drive.
windows device manager only says "drive" without further information. I can see the hard disk with tools like MHDD or HDAT2. But I dont seem to be able to do very much with them. At one point HDAT2 says "DCO status = frozen"
There must be some kind of communication to the drive though. Like if I select erase under MHDD it apparently tries to reset the drive and yet I can hear a click sound from the drive...
is there anything I could still try to do except putting it into the trash?
thx
regards
Peter
 Post subject: Re: WD3200BEVT locked? frozen? dead? wth?
PostPosted: May 31st, 2012, 5:57
if the hdd is detected (but locked) still i think u can use it
but which App. u tried to update it?
PostPosted: May 31st, 2012, 6:35
I uses HDD hacker with my X360USB Pro Kit...
HDD hacker sees the drive as well. It says the drive might be locked and it asks me if it should attempt an unlock which eventually fails every time...
PostPosted: May 31st, 2012, 13:08
so basically, ur hdd was OK and not locked, and u used this App to flash it and at some point it failed
then you discovered that it is locked?
am i right some how here?
PostPosted: May 31st, 2012, 14:16
If I read it correctly, the OP bricked the drive by doing a partial firmware update trying to fudge the drive to detect on an xbox.
As there is no data of value on the drive, I suggest that you give up and buy a proper drive for your xbox. Had you fully backed up all the SA tracks and modules prior to the update, it would be easy to revert back. It is not so easy now. Certainly the cost of a pro or the tools to do it yourself will be far greater than the cost of a new drive.
PostPosted: May 31st, 2012, 15:35
Or find someone who refurb drives in his area...
I have the feeling these sw make more damage than good...
PostPosted: May 31st, 2012, 18:24
before I updated the firmware, I saved the one that was on it. So now I have a file called hddss.bin with the size of 3584 bytes. Can I do anything with it? I tried to flash said bin with hddhackr but eventually I got an error 0x0802
I know it would be quicker to just buy a new drive since they are quite cheap in the first place. sitting here a half hour would probably be more expensive that buying a new drive.
but still I would like to try to get it to work, just out of curiosity...
Peter.
PostPosted: May 31st, 2012, 18:54
Out of curiousity i upgraded my 4gb xbox with a 120gb wd bevt drive tonight to test.
The process is straight forward & worked fine on mine.
Firstly did you download the correct hddss.bin ie the 320 one?
Secondly did you create an undo.bin
If so have you tried using hddhackr -r to try to restore it?
If that works then you can try again.
As far as i can see from your pics they dont show the drive make, model or serial details. In bios what does it see the drive as? The reason i ask is that mine changed from displaying wd to fujitsu. When i fitted the drive into the xbox i went to settings & formatted it.
Loki
PostPosted: February 13th, 2013, 12:38
Welcome all - my first post!
I have hard disk Hitachi C5K500 B-320GB (CinemaStar) and I have the same problem! Disk don't has password, but i can not view data/sectors and don’t create partition or password – status with program HDAT2: !DC0 FROZEN DISK ??
PostPosted: February 14th, 2013, 7:25
Agreed.
PostPosted: February 14th, 2013, 14:04
No one will help me? :(
PostPosted: February 14th, 2013, 17:10
peter,have you found any help?.you and i have similar problems..
PostPosted: February 14th, 2013, 17:18
With the disposable nature of hardware these days, I'd just replace it.
PostPosted: February 14th, 2013, 19:00
DCO frozen state is not an issue at all. It's one of the normal states of a drive
PostPosted: February 15th, 2013, 1:57
what if its disabled?..what impact on the drive would that have?
PostPosted: February 15th, 2013, 6:52
OK, but I can not create a partition any programs.. error inputs / outputs ?? Drive is somehow locked (?) it is not password?
When I want to create password/erase by mhdd - "fail", scan - "! ABRT", create partition - "no access error inputs/outputs"
PostPosted: February 15th, 2013, 9:00
when you go to issue commands on it ata commands sata commands etc etc,does it actually let you?.or do you get that annoying beep when they fail all the time every-time?...i have a wd3200avjs..so im very curious to your problem. Mhdd wont see mine at all. my bios sees it as all zeros on every single attribute,Hdat2 sees it as a PCI device with 0 bytes....i wonder if the WD3200 line of drives was just a pig in a poke?
i did find this and wanted to share it..its a list of just about every single (and free) hard drive diagnostic tool out there. perhaps there is something there than we havnt seen or tried before that can give us some help...have you tried HDDhackr?..ive been reading how it has a feature that lets yo rebuild certain features/functions/attributes by hand...is MS-dos based like everything else.
http://alternativeto.net/software/smart-utility/
i apologize if im not allowed posting this here..if i am in the wrong please tell me and i will remove asap.
PostPosted: February 15th, 2013, 10:01
That's an issue
PostPosted: February 15th, 2013, 11:36
how to break, to restore to factory settings? Modifying an image (?) such as the xbox 360? I have oryginal FW with model HTS, but my is HCC.. ehh
PostPosted: February 16th, 2013, 12:51
@KOBRA000
Sorry, only now I noticed your reply :?
Yeah, all sectors/attribute is locked. I've tried all applications even those you suggested. BUT!
I dont know how it works HDDHacker - is he doing a backup?
I search FAQ on this program in the end he breaks the xbox drives.
In Poland 15-17y boy... unlock these drives, I do not know how he does it.
However, these drives are set to zero - so running hdparm? but I dont want to set up a password, dont know why hmm
Users browsing this forum: No registered users and 42 guests
