 Post subject: WD20EARS Formatting Aligning
PostPosted: June 4th, 2012, 3:56
I am using WinXP and WD20EARS as a second HDD. Pins 7 and 8 are with Jumper. Then i format it in WinXP do i need to do Alinging with WD Tools powered by Acronis?
Thanks for answers
Greetings from Lithuania
 Post subject: Re: WD20EARS Formatting Aligning
PostPosted: June 4th, 2012, 12:25
This is not a data recovery or repair question and therefore it is off-topic for this board. IMHO this type of sys-admin question is better directed at the manufacturer's support. IIRC your answer depends on whether there are multiple partitions on the disk or not, but I expect you will find advice in the WD website support section.
Users browsing this forum: Google [Bot] and 198 guests
