 Post subject: WD4000AAJS HD. PCB TVS replacing.
PostPosted: June 5th, 2012, 20:44
Hi! I'd like to try to replace SMAJ5.0A TVS diode on my PCB for the WD4000AAJS hard drive. How can I find it on the board and how it is marked?
Thanks in advance.
 Post subject: Re: WD4000AAJS HD. PCB TVS replacing.
PostPosted: June 5th, 2012, 20:55
Diode at D4 looks damaged
PostPosted: June 6th, 2012, 0:41
Agree, in which case an SMBJ12A would be a suitable replacement, not SMAJ5.0A.
See http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
... and http://www.users.on.net/~fzabkar/HDD/bi ... diodes.jpg
PostPosted: June 6th, 2012, 4:32
Thanks in advance.
how did you know that it is the TVS? is it someone recommended you to do so?
that is the question
thank you
PostPosted: June 6th, 2012, 14:33
Thank you everyone for the answers. I am not 100% sure if it is one of those diode but I suspecting this. The multimeter diode test show me the following results:
D3 (=5v) resistance: 0.L, 0.5
D4 (=12v) resistance: 0.0, 0.0
so I am assuming that D4 is died. As fzabkar pointed it is SMBJ12A diode.
PostPosted: June 6th, 2012, 15:10
Yes, D4 is shorted (i.e. failed), as labtech and fzabkar discussed above.
PostPosted: August 14th, 2012, 20:42
I am still fighting to recover my data from the dead drive. PCB does nor work. I am trying to find the donor drive. Need advice if the following HD can be used as a donor:
MY HD: WD4000AAJS-00YFA0, Date: SEP 2007, DCM:HHRNHT2AHB, LBA: 781422768, Made in Thailand
Potential: WD4000AAJS-00YFA0, Date: SEP 2007, DCM:DHNCNT2MHN, LBA: 781422768, Made in Thailand
Thanks in advance for the help.
PostPosted: August 15th, 2012, 1:07
The suitable donor you want is readily available, it's only not cheap...
PostPosted: August 15th, 2012, 16:45
Sorry, not sure what you meant by "readily available"
My question was: "Is the drive I found and called the POTENTIAL WILL work as donor drive OR NOT?"
PostPosted: August 15th, 2012, 17:28
have you tried just unsoldering the TVS at D4 and then trying the board?
If that works, get the data off and put it on a different drive
Users browsing this forum: No registered users and 292 guests
