 Post subject: Toshiba 1.8" Drive
PostPosted: May 31st, 2012, 10:15
Good morning. I have a Toshiba1.8" drive a customer brought me from a Sony camcorder. The specifics on the drive are:
MK4009GAL HDD1682 H ZR01
I can find drives that match everything but the ZR01. All of the drives I have seen have ZL01. Is this a firmware specification? Do I need to
match it if I am taking chips off the original and putting it on the donor?
Thank you,
Philip Shaw
 Post subject: Re: Toshiba 1.8" Drive
PostPosted: June 1st, 2012, 13:55
What is your primary goal?
www.datarecoveryne.com
PostPosted: June 1st, 2012, 19:10
The drive I received is getting no power. I removed the TVS diodes but that didn't help. I would like to move the NVRAM chip from the customer drive to the donor and see if that works. I have tried this once but the customer drive had ZL01 and the drive I had had ZR01 and I am not sure if that is why it didn't work. There is very little documentation that I could find so I moved the two 8-pin chips over. I am wondering if I need to move one of the other chips instead.
Thanks,
Philip Shaw
PostPosted: June 1st, 2012, 19:18
No external ROM on these drives :-(
PostPosted: June 1st, 2012, 20:16
I was thinking it was the BGA chip with the M on it. Does that sound correct? No fun to change that one.
PostPosted: June 6th, 2012, 2:12
That doesn't sound right. AIUI, your drive has a single 3.3V supply, in which case it would probably only have one TVS diode, if it has any at all.
Could you show us a photo of the board?
PostPosted: June 6th, 2012, 2:27
This is what we exactly CALL IT FUN.
Users browsing this forum: Thedatarecoverylab and 195 guests
