 Post subject: How to identify dead PCB
PostPosted: June 10th, 2012, 18:07
Hi All,
I have a dead WD3200AAJS that does not spin up no noise at all. Thought it might be the PCB, took the PCB out and there is no visible damage at all.
Is there a way to measure voltage across certain points to see if it actually is the PCP? Since that drive has the bios on the main chip it is way beyond me to remove and re-solder it onto a working PCB. Any help is appreciated.
 Post subject: Re: How to identify dead PCB
PostPosted: June 10th, 2012, 22:58
Use the search funtion for TVS, diode, etc. You should find plenty of info.
PostPosted: June 11th, 2012, 17:10
Pitbull2k wrote:
Hi All,
A damaged PCB doesn't necessarily need "visible damage" to not work.
Nationwide data recovery services for RAID servers and laptops - http://www.harddriverecovery.org/
PostPosted: June 13th, 2012, 13:26
I figured it can still be dead, due to time constrains i have, i bought a pcb, and sent in the drive for the IC swap, hopefully that will do it.
Thanks for the input guys.
PostPosted: June 14th, 2012, 14:16
I have the same problem with the hdd not spinning , but on the other had the pcb warms up when power is applied it is a WD3200BEVT-08A23T1.
Just wanting to know if I swap the pcb with a donor, would it work?
Thx
PostPosted: June 14th, 2012, 14:19
Rarely, most of the time it does not.
PostPosted: June 16th, 2012, 19:57
Got the PCB replaced and bios transferred, drive is alive again.
Users browsing this forum: No registered users and 231 guests
