 Post subject: Recovery Data
PostPosted: June 15th, 2012, 5:00
I've a 500GB Hard Drive of WD Cavier Blue
And this Hard Drive is all ready full.
Few days ago, I just turn the Bitlocker on. After Encrypting 19 or more System says to do "Chkdsk /f" and try again. But tried to do that, i'm failed to do.
Now I can't open the Hard Drive.
Please give me a way to get my Data.
 Post subject: Re: Recovery Data
PostPosted: June 15th, 2012, 8:35
keep the drive disconnected and contact pro
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: June 15th, 2012, 13:14
If I Contact the Provider, what will be solution for my Data. I need my Data.
PostPosted: June 16th, 2012, 10:10
Provider will mess up/temper the drive - contact only DR Pro.
__________
THANK YOU
SHAHI
PostPosted: June 16th, 2012, 11:24
Did checkdisk actually run? As in did you see a progress process fixing anything?
PostPosted: June 17th, 2012, 16:19
If this is an important disk with important data, and you don't know what you're doing, best hire out a pro. Now is not the time to learn how to do these types of operations.
PostPosted: June 18th, 2012, 9:32
suggestion to run chkdsk /r shows that the drive has bad blocks you disk is failing physically
PostPosted: June 19th, 2012, 1:24
In the Process of Checking, it's says "Invalid Parameter".
PostPosted: June 19th, 2012, 4:21
ur case may have degraded head or bad blocks, in this situation never run chkdsk which will degrade the case more, even may be make it worse.
http://blog.vsrcbd.com/?p=87
http://blog.vsrcbd.com/?p=81
__________
THANK YOU
SHAHI
PostPosted: June 21st, 2012, 6:49
Clone it with DMDE or HDClone (or DD if you're familiar with linux)
data recovery Poland
Users browsing this forum: No registered users and 94 guests
