 Post subject: New DR Lab Setup - Comments Appreciated
PostPosted: April 1st, 2012, 9:56
Guys ,
My New Lab is Under Construction Now .In This Lab My Main Work Area Has a Roof Thats 8 Feet in Height .The Room dimension is 14 Feet X 14 Feet .The Room Has Two Hepa Air Filters Filtering The Outside Air To Go Into The Room .The Pressure Of Air Thats Created Inside goes out from the main door .It has a 1 Inch Gap At the Bottom To Remove The Air Pressure Inside The Lab .This room has My HDD Repair Bench and Flash Media Repair Bench also .All My HDD are also stacked in The Same Place That Are used For Donors .This will house another small room which will have My laminaar flow bench .As we Do not have good Clean room professionals at this side of india .I would like to ask for your suggestions and inputs also .Work is still going on ...
 Post subject: Re: New DR Lab Setup - Comments Appreciated
PostPosted: April 2nd, 2012, 10:38
Guys ,
Adding a small Picture Of the Plan
PostPosted: June 17th, 2012, 3:17
Respectedn Sir,
I saw your plan for the clean room, nice work. I have recently purchased tools from salvationdata and i want to build a clean room. Can u tell me what are the things needed to build a clean room. It would be gratefull if you help me.
PostPosted: June 18th, 2012, 4:13
Do you have any previous experience in Data Recovery??
PostPosted: June 18th, 2012, 5:40
Not a good start in my opinion :(
PostPosted: June 18th, 2012, 5:44
Agree totally
Users browsing this forum: No registered users and 75 guests
