 Post subject: 7200.12: spins, never ID's, terminal garbage
PostPosted: June 22nd, 2012, 0:26
Terminal just gives garbage:
b?J(^A?Zb{?
any ideas? Not seen this before, and I am terrible with Seagate FW issues....
Many thanks
 Post subject: Re: 7200.12: spins, never ID's, terminal garbage
PostPosted: June 22nd, 2012, 1:16
Are you sure your baud rate is correct?
Data Recovery Cape Town
PostPosted: June 22nd, 2012, 2:46
Should be 38400 as I recall.
PostPosted: June 22nd, 2012, 5:55
your baud rate is wrong.
PostPosted: June 22nd, 2012, 8:27
thanks for the input. baud rate is fine, 9600, atola default. tested: good similar disks read fine.
any more ideas?
FW is CC66, stays bsy
PostPosted: June 22nd, 2012, 8:28
PostPosted: June 22nd, 2012, 8:33
you were right guys. thanks!
Users browsing this forum: Google [Bot] and 59 guests
