 Post subject: LDR for Kermit WD10EAVS
PostPosted: June 28th, 2012, 11:45
Hey all
Looking for loader for this little monster:
WD10EAVS-00D7B1
Version: 000500CE
Thanks all
 Post subject: Re: LDR for Kermit WD10EAVS
PostPosted: June 29th, 2012, 1:24
Hi
Here you go:
LDR.rar [139.01 KiB]
Downloaded 306 times
www.datasave.ro
PostPosted: June 29th, 2012, 2:50
Thank you my friend.
I'm gonna give it a try now :)
PostPosted: June 29th, 2012, 4:16
Beat me to it!
Here's another one anyway...
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 6
>Cyl Count............................... : 170
>Zone allocation table................... : Ok
>SA SPT.................................. : 1325
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.CEE
>ROM generation.......................... : 05.CEE
>Link table version...................... : 04.3F.
>Consolidated ROM version................ : 000500CE
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>Heads configuration..................... : by map
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Heads map............................... : 2,3,4,5,6,7
>ROM Firmware version.................... : 000500CE
>Service area:
>SA dir reading.......................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [139.02 KiB]
Downloaded 261 times
PostPosted: June 29th, 2012, 4:54
Thanks Sean
It seems this is a little more complicated than I first thought.
PostPosted: June 29th, 2012, 9:14
D7's often are
9/10 times been dropped with platter damage :-(
PostPosted: June 29th, 2012, 9:20
Unfortunately correct
pcimage wrote:
D7's often are
www.datasave.ro
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 143 guests
