 Post subject: My Passport Problem
PostPosted: July 10th, 2012, 6:53
I have a problem with a MY Passport USB 3.0 which contains a WD5000BMVW-11AMCSO.
This drive on first appraisal was not spinning up but the PCB was receiving power (led on).
I acquired a replacement PCB from HDDZONE (2060-771737-000) rev P1 and was advised that the serial ROM for the SYMWAVE at U8 and the serial ROM for the firmware at U12 would need swapping.
I tried the replacement PCB just to see if the drive did spin up and this was successful. I then got U8 and U12 chips transfered via a third party , which appears successful, however on return the replceement PCB displays the same symptoms as the original.
Although the the drive does not spin up it is detected as a generic WD mass storage device and displays the following
in USB viewer
iManufacturer: 0x01
English (United States) "Western Digital"
iProduct: 0x02
English (United States) "My Passport [#]"
iSerialNumber: 0x03
English (United States) "158744C3158745DF"
bNumConfigurations: 0x01
 Post subject: Re: My Passport Problem
PostPosted: July 10th, 2012, 10:58
What does "however on return the replceement PCB displays the same symptoms as the original." mean in regard to the first part of the sentence. Seems confusing.
PostPosted: July 10th, 2012, 11:15
I think he means the drive doesn't spin up.
In this case, assuming "third party" did transfer the chips correctly, and assuming everything else has been done properly, possibly a corrupted ROM is preventing drive from spinning up.
PostPosted: July 10th, 2012, 11:16
PS.
in USB viewer
iManufacturer: 0x01
iProduct: 0x02
iSerialNumber: 0x03
This is caused by the usb controller, it has nothing to do with your actual drive.
PostPosted: July 10th, 2012, 12:29
I've seen this a few times before.
Data Recovery Cape Town
PostPosted: July 10th, 2012, 15:49
Ok, I read few more times. Now, I understand.
Are you sure the drive does not emit any sounds if listening to it closely? Like buzz or a hum?
PostPosted: July 10th, 2012, 18:39
The drive does spin up and emits no noise.
I have read a description which said the PCB MCU first does a check of the U12 rom and if corrupt does not spin the drive up.
PostPosted: July 10th, 2012, 18:40
SORRY PREVIOUS POST IS WRONG.
THE DRIVE DOES NOT SPIN UP NOR EMIT NOISE.
PostPosted: July 11th, 2012, 4:38
PostPosted: July 11th, 2012, 8:21
northwind wrote:
How do you repair these with USB 3 connectors???
I have heard of 2 ways either get a replacement SATA PCB and swap U12
or
rewire the USB3 by taking of some capacitors and some additional soldering?
PostPosted: July 11th, 2012, 8:49
digger1 wrote:
I have heard of 2 ways either get a replacement SATA PCB and swap U12or rewire the USB3 by taking of some capacitors and some additional soldering?
Both won't help.
PostPosted: July 11th, 2012, 8:59
Just for Info:
That way is for attaching a SATA connection to the PCB to bypass the symwave, JM or initio encryption chip either way the data will still be encrypted.
If your accepting DIY & the RISKS involved then you could try reflowing the USB soldering connections - could be a bad joint
or you could try something like this wd10tmvv-t16204-180.html?hilit=wd%20usb%20loki%20cable#p156543 but you would have to work out the correct points to connect to.
But if the data is important then I would advise to take it to a DR pro
Loki
PS Why are you jumping to the USB connection? As previously mentioned it could be corrupt ROM
Proper diags is required not guess work. its simple to test the USB connection just use a multimeter.
PostPosted: July 11th, 2012, 18:14
unknown wrote:
Both won't help.
What is the method to fix then?
PostPosted: July 12th, 2012, 10:09
The method beyond normal user abilities. You will need a pro assistance to fix your drive with special tools and knowledge.
PostPosted: July 12th, 2012, 20:06
Can you describe what needs to be done. I am more than happy to take it to someone who says there a pro as long as they can tell me otherwise I cannot tewll if there a pro.
I am guessing we need to reflash the ROM but can this be done without desoldering.
Users browsing this forum: No registered users and 292 guests
cron
