 Post subject: SEAGATE FIRMWARE ISSUE
PostPosted: July 13th, 2012, 1:40
Is it possible to repair the following problem through Salvation HD Doctor for Seagate
Model : ST_M13FQBL
Serial : QNR_BFW
Firmware : 03171104
Capacity : 3.86 GB (8 089 950)
Original Model is ST3500413AS-FIRMWARE JC4B
I already tried with pc3000udma but there is no use
With regards
Sundar
 Post subject: Re: SEAGATE FIRMWARE ISSUE
PostPosted: July 13th, 2012, 2:25
datacare wrote:
Model : ST_M13FQBL
Serial : QNR_BFW
Firmware : 03171104
Means drive cannot read SA, most likely heads are bad.
PostPosted: July 13th, 2012, 3:39
:good:
PostPosted: July 13th, 2012, 8:40
After powering the drive on, it spins, and then what? It stays spinning until you power it off?
PostPosted: July 14th, 2012, 15:04
bad head
DF :)
www.datatracksystem.net
Users browsing this forum: No registered users and 6 guests
