 Post subject: WD Elements recovery
PostPosted: July 16th, 2012, 15:43
Greetings everyone,
I am recovering a 2GB WD Elements HD. It's been used for video editing and crashed during rendering of the video. MHDD scan showed 197 bad blocks (UNC) which were removed after I scanned it with HDAT2. I had a drive image already (done w Acronis True Image), but after UNC's were gone I could mount the drive and access files without any problem or hang-ups. I copied all the files on another drive and proceeded with fixing the Drive itself. I scanned it w MHDD and discovered that there are still delays showing up - 9 Brown (less then 500ms), 32 Green, and 580 w less then 50 ms.
I did full erase, scanned with erase and with remap, but non of this removed delays.
So I have 2 questions.
1. Can I do anything to remove at least the Brown delays?
2. Can I do anything to make this a usable drive? I don't have any warranty on it and would like to keep using it, what are my risks/options?
Thanks in advance,
Nick
 Post subject: Re: WD Elements recovery
PostPosted: July 17th, 2012, 2:06
is there any software that better fixes the delays?
PostPosted: July 17th, 2012, 16:12
I'm not a newbie and I can figure things out, but maybe someone has an experience to share... :)
PostPosted: July 17th, 2012, 16:48
First have you read the mhdd manual?
If so you know about the cfg file.
CFG/mhhd.cfg file
as observed
N.B. # is NOT a comment but is included in every(?) line.
Turning on Erase Delays in scan parameters will destory data
Add this line #SCAN_ERASEWAITSDELAY=350 to the cfg file but changing the 350 value to what you want.
Are you accepting the risks involved with DIY?
If the above fails then your out of DIY options as expensive specialist DR tools would be required unless you send it away for a refurb?
Loki
PostPosted: July 17th, 2012, 21:52
Thanks Loki.
I backed up all the data, I just want to fix the delays on the drive.
From your experience, what do I risk leaving them as they are? There are 9 Brown and 31 Green delays at this moment.
PostPosted: July 19th, 2012, 14:20
you use mhdd? if yes, press F2 and typing not scan or F4, type erase, and you not see screen, but after when done erase, make scan one more time, and see what is gone one
PostPosted: July 19th, 2012, 15:49
@HDData:
HDData wrote:
type erase
The OP says they have already done a full erase:
kolik wrote:
I did full erase
PostPosted: July 19th, 2012, 16:34
Then two options can be, you need to check the system does not work well whether it is see how many slow sectors ..... you found in the first case, if scan one more time, and seeing the exact value of the estimated similar to the first, then only specials. program, you need to scan the drive with the hidden defects in Psheet, I do it with a program ps3000
PostPosted: July 22nd, 2012, 3:09
yes, did full erase ;)
gonna look into that ps3000 soft you mentioned
PostPosted: July 23rd, 2012, 19:17
this is not cheap soft
PostPosted: July 23rd, 2012, 19:23
You will not find in the free access that program, because it contains a PCI card
PostPosted: August 2nd, 2012, 22:17
ok, thanks, I guess I'll give a try to this option mentioned in the beginning
"CFG/mhhd.cfg file
as observed
Add this line #SCAN_ERASEWAITSDELAY=350 to the cfg file but changing the 350 value to what you want. "
The only thing I don't get is, why wouldn't the soft erase delays automatically, since it can detect them, would the above suggestion do anything differently?
Also, do I need to erase only 500 and over delays or all of them - 150, 50ms?
Thanks!
PostPosted: August 3rd, 2012, 23:25
after setting ERASEWAITDELAY=500 I got nothing out - msg at the end of the scan said no delays were erased - ???
PostPosted: August 4th, 2012, 5:54
You previously said " I scanned it w MHDD and discovered that there are still delays showing up - 9 Brown (less then 500ms), 32 Green, and 580 w less then 50 ms "
So when you set ERASEWAITDELAY=500 thats for anything over 500ms
Try a lower number :wink:
Loki
 Post subject: Re: WD Elements recovery - Erase Delays
PostPosted: August 9th, 2012, 18:08
hey loki! it works! Thanks a lot!
I figured out how to edit mhdd.cfg and SET ERASEWAITSDELAY=50
scanned with EraseDalays ON
now I have all those delays removed,
but I got one UNC.
I used to have more of them, but I believe they were gone after disc erase. What can I do with UNC?
PostPosted: August 9th, 2012, 19:39
I'm over with this, after I erased the waits, and got UNC, I attempted to remap the UNC block, which didn't seem to work, but I got a lot of delays back. WTF! I thought it's a permanent solution! :lol:
Dear all, unless you advise otherwise, I'm gonna trash that drive. I've learned a lot, but it seems the drive is faulty beyond repair. Please advice if you think otherwise.
PostPosted: August 9th, 2012, 19:51
Perhaps not beyond professional refurbishment, but based on your initial description, IMHO it always looked beyond anything more than temporary life-support using DIY, yes. :(
PostPosted: August 10th, 2012, 2:48
thanks all :idea:
PostPosted: August 10th, 2012, 9:14
No DIY , just pro refurb - sorry.
Users browsing this forum: No registered users and 50 guests
