 Post subject: Seagate ST1000DL002 burned PCB 100617465 REV B
PostPosted: July 27th, 2012, 13:10
Hello, i've this Seagate ST1000DL002 with burned PCB.
PCB number is 100617465 REV B
I'm going to repair it with wire wrap and capacitor substitution (but i don't know it's value), someone does it know the value of the capacitor indicated in the pic?
There are also 2 destroyed fuse, but i don't care because i'm goin to substitude them with wire wrap, i nedd your help for the capacitor value. Does any of you know the value?
Thank you.
As you can see in the pic,
My firmware database:
 Post subject: Re: Seagate ST1000DL002 burned PCB 100617465 REV B
PostPosted: July 27th, 2012, 13:29
Pessima idea. Auguri.
Really bad idea. Good luck.
PostPosted: July 27th, 2012, 13:30
If you not sure which parts are needed, get a new PCB.
www.datarecoveryne.com
PostPosted: July 27th, 2012, 18:31
Perchè pensi che sia una pessima idea?
Sono bravo con l'elettronica
Why do you think it's a bad idea?
I'm good with electronics
I just need to know the capacitor value, and i can bypass the 2 microfuse with wire wrap.
I don't care if the pcb will burn more, in case i buy a new one.
I have soldering iron, hot air soldering gun, multimeter, capacitor tester, wire wrap and a lot of practice in SMD micro electronics
PostPosted: July 28th, 2012, 13:24
I substituted the capacitor with onother of 10uF (micro farad).
Instead of 2 microfuse i put 2 wires (one cannot even see in the pic), rebuilding at the same time the tracks burned.
PostPosted: August 9th, 2012, 9:54
Repaired :D
I substituted the capacitor with a good 10 uF capacitor and the TVS 5 volt diode.
2 microfuse are impossible to substitute, so i put 2 wires.
PostPosted: October 14th, 2012, 6:58
Hi Michael,
Congrats on your HDD recovery. Thankfully, I ran into this post after my HDD PCB failed a few months ago, with the exactly same blown caps.
I replaced the SMD caps, but the motor still isn't spinning. You mentioned micro fuses; can you tell me where they are please?
Thanks!
PostPosted: October 18th, 2012, 4:05
Look at the 2 red arrows, those two are microfuse
Don't forget to check the 2 tvs diodes and the mosfet, look at the pic in the bottom.
Good luck :wink:
PostPosted: October 26th, 2012, 10:04
Thanks for your reply.
However, I'm still not so sure of the microfuses. The arrows you put point to the two SMD caps I've replaced...
Here's a better picture:
Appreciate it!
PostPosted: October 26th, 2012, 11:09
It would help if you explain how you decided that they are capacitors.
If they are in series with the +5V supply, which they seem to be on that photo (you'll have to check yourself, since you have the PCB in your hands and I don't!) then they cannot originally have been capacitors.
PostPosted: October 26th, 2012, 11:19
Doh! Yeah, I hastily confused the black microfuses with SMD caps.
I haven't realized that these black things were fuses; I didn't know they even exited!
Warming up the soldering iron again... :lol:
Thanks mate!
PostPosted: March 7th, 2013, 12:38
Check for continuity by using multi-meter, put multi-meter in continuity mode. Connects the terminals of meter to either ends of micro fuse, if it bad continuity will not be shown.
PostPosted: March 7th, 2013, 13:37
@ denton88
That Post was more than four months old...
and he must have got his data too..
Check for posted date on top right corner of the post.
PostPosted: January 17th, 2014, 4:16
Prompt what this kompanenty and their denomination
PostPosted: January 17th, 2014, 6:53
100617465 REV B
PostPosted: January 17th, 2014, 15:58
Answered in your new thread:
viewtopic.php?t=27745&p=190316#p190316
PostPosted: January 18th, 2014, 6:58
here see in this picture about repairing this pcb . in your pcb two fuse are burn and 1 diode .
see this picture
PostPosted: February 4th, 2014, 8:28
I do not speak English.
I'm from Brazil.
My HD spoiled / damaged
I use a case for HD.
Someone connected cable notebook 19 volts.
My case uses 12 volts.
Two capacitors burned. I will post photo.
THAT HAS REPAIR? THIS IS SOLUTION?
romulominduin@yahoo.com.br
File comment: My PCB HDD 100617465 REVB model : ST1000DL002
PostPosted: February 4th, 2014, 16:06
Remove the 12V TVS diode. It will be shorted.
PostPosted: February 5th, 2014, 7:16
Banned User
Thank you.
You can buy the capacitor within $7.
Users browsing this forum: Google [Bot], sixsweets and 46 guests
