 Post subject: Need heelp for WD USB DISK HEADS Compatibility
PostPosted: August 1st, 2012, 0:21
Got one head down on WD10TMVV-11TK7S1, I find WD10TMVW-11ZSMS5, But not sure on compatibility
donor :
WD10TMVW-11ZSMS5
17 MAY 2012
DCM:EHMT2HBB
patient :
WD10TMVV-11TK7S1
19 JUL 2011
DCM:HHMT2BBN
head map is same :0 1 2 3 4 5
thanks in advance for all HDD guru
 Post subject: Re: Need heelp for WD USB DISK HEADS Compatibility
PostPosted: August 1st, 2012, 2:53
None guru anwser me . so I try it ! try try
PostPosted: August 1st, 2012, 3:09
I think they're both Helios, so it should work. I'd go for it.
PostPosted: August 1st, 2012, 4:12
yes , it work :)
PostPosted: August 1st, 2012, 7:46
Good job :)
