 Post subject: Samsung HM641JX unrecognised by Win7
PostPosted: August 13th, 2012, 12:09
Hello. I am trying to recover data on a Samsung HM641JX USB external HDD.
I need to connect with two ports to get it to light the blue LED and then it fails to be recognised by the OS (Win7) which gives the error message "USB Device not recognised One of the USB Devices attached to this computer has malfunctioned and Windows does not recognise it". The drive is spinning and sounds OK.
Any suggestions please?? Thanks in advance.
 Post subject: Re: Samsung HM641JX unrecognised by Win7
PostPosted: August 13th, 2012, 12:44
Have you already removed it from the case and conected directly to a PC?
ACELab partner
PostPosted: August 13th, 2012, 12:59
Hello thanks for your reply. Yes I have opened the case but in fact the connector (micro USB) goes direct to a PCB on the HDD.
PostPosted: August 14th, 2012, 2:37
Samsung HM641JX, I like this model of mobile phone...
PostPosted: August 14th, 2012, 7:08
I think you are slightly misunderstood...
You should get this properley diagnosed by a professional, but my initial thoughts are that there is some internal short circuit somewhere in the USB bridge or the PCB itself.
Again, without proper diagnosis this is just a guess..
PostPosted: August 15th, 2012, 23:09
Thanks yes I suspect a power supply problem but as you say I will get a professional to attempt a recovery. Thanks for your time Cheers
Users browsing this forum: Google [Bot] and 236 guests
