 Post subject: ST3750640AS .. pending solution
PostPosted: August 13th, 2012, 10:49
I have Seagate ST 37500640AS ... it reading very slow in DE ... when spin up it spin with clicks but reads it FW too ,,,, But DE extractor it reads extremely slow .. did change PCB and HDA .. but same thing any help will be appreciate ....
 Post subject: Re: ST3750640AS .. pending solution
PostPosted: August 13th, 2012, 11:02
Search "pending bug".
Built heads map?
PostPosted: August 13th, 2012, 13:20
Thanks lab tech ... id head maps ... then how i find the pending error...?
PostPosted: August 13th, 2012, 13:27
Post terminal output here
PostPosted: August 13th, 2012, 13:31
Terminal Data
DiskAccess ReadSector EC=43 at 0165dd.07.0014
CE Log ErrCode=43 LBA=3e5671e9 Type=5 Add To Pending 3e5671e9
$SFI
AMR
AT Er 00 Nwt Er 43 RdWr 165dd.07.0016
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 9ff79ff7 b6 9ff79ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 0165dd.07.0016
CE Log ErrCode=43 LBA=3e5671eb Type=5 Add To Pending 3e5671eb
$SFI
AMR
AT Er 00 Nwt Er 43 RdWr 165dd.07.0018
DiskAccess ReadSector EC=43 at 0165dd.07.0018
CE Log ErrCode=43 LBA=3e5671ed Type=5 Add To Pending 3e5671ed
$SFI
AMR
AT Er 00 Nwt Er 43 RdWr 165dd.07.0019
DiskAccess ReadSector EC=43 at 0165dd.07.0019
CE Log ErrCode=43 LBA=3e5671ee Type=5 Add To Pending 3e5671ee
$SFI
PostPosted: August 13th, 2012, 13:35
There you go - examine the output!
You have PC3K book? Read on "extended utility settings".
PostPosted: August 13th, 2012, 15:08
Well ..,, i did not get it i try to read the book but did not get what to do and more clues may help
PostPosted: August 13th, 2012, 15:22
Sent PM
PostPosted: August 13th, 2012, 15:25
Oops...............................................
PostPosted: August 15th, 2012, 15:42
There's a step by step on the ACE forum for pending bug, read it.
Data Recovery Cape Town
PostPosted: December 31st, 2012, 10:49
Hi
I also have this bug.
This is the terminal log, when I try to read sectors, but SD doesn't know nothing about this.
T>DiskAccess ReadSector EC=47 at 00015d.02.00bb
CE Log ErrCode=37 LBA=306447 Type=5 Add To Pending 306447
AT Er 00 Nwt Er 37 RdWr 0015d.02.00bc
NiwotDiskAccess ReadSector EC=47 at 00015d.02.00bc
CE Log ErrCode=37 LBA=306448 Type=5 Add To Pending 306448
DiskAccess ReadSector EC=47 at 00015d.02.0313
CE Log ErrCode=37 LBA=30669f Type=5 Add To Pending 30669f
DiskAccess ReadSector EC=47 at 00015d.02.0314
CE Log ErrCode=37 LBA=3066a0 Type=5 Add To Pending 3066a0
AT Er 00 Nwt Er 47 RdWr 0015d.02.0315
ATA St 50 Er 00 Op 20 e, 004c404,01 00 00
Niwot: 9ff79ff7 b6 9ff79ff7.4.642 0000 005f 0000 9ff7
DiskAccess ReadSector EC=47 at 00015d.02.0315
CE Log ErrCode=47 LBA=3066a1 Type=5 Add To Pending 3066a1
AT Er 00 Nwt Er 47 RdWr 0015d.02.0316
DiskAccess ReadSector EC=47 at 00015d.02.0316
CE Log ErrCode=47 LBA=3066a2 Type=5 Add To Pending 3066a2
AT Er 00 Nwt Er 43 RdWr 0015d.02.034a
DiskAccess ReadSector EC=47 at 00015e.02.0201
CE Log ErrCode=47 LBA=306b7b Type=5 Add To Pending 306b7b
AT Er 00 Nwt Er 47 RdWr 0015e.02.0202
Niwot: 9ff79ff7 b6 9ff79ff7.4.642 0000 005f 0000 006a
T>
Can some one give a hint?
ACELab partner
PostPosted: December 31st, 2012, 11:25
pclab wrote:
Hi
T>
You have an EMAIL....
good luck man... :wink:
PostPosted: January 1st, 2013, 11:50
Problem solved. Thanks
ACELab partner
PostPosted: January 3rd, 2014, 23:32
Hi can someone provide the hint here for thid problem?
I went to the PC3000 forum and in DE I am not able to
select the extended utility. It's a check box that ignores
being checked!
I created the loaderto use in DE but am stuck.
Any help will be greatly appreciated.
-Drew
PostPosted: January 4th, 2014, 9:07
What do you mean?
The extended utilities checkbox is grayed out??
Users browsing this forum: No registered users and 77 guests
