 Post subject: DDI - I have to Admit it
PostPosted: August 16th, 2012, 14:11
Guys,
I Have to Admit it, this Great Imaging tool is really Making me Smile..
worth every single cent invested on it....
Many thnx to Serge & Pavel and Yarek as well.
it is time now to save some time here...
seems have a lot of puzzles to solve n discover here
Good luck All... :wink:
 Post subject: Re: DDI - I have to Admit it
PostPosted: August 16th, 2012, 14:32
Definitely, the best applied money I ever invested on DR so far.
This thing does wonders.
ACELab partner
PostPosted: August 16th, 2012, 15:29
better than DE?
I don't think so.
PostPosted: August 16th, 2012, 15:38
DDI is good...but always my second choice, DE is king.
Data Recovery Cape Town
PostPosted: August 16th, 2012, 15:39
HDD Spaz wrote:
better than DE?
I don't think so.
hehehe, you SHOULD start thinking again my friend...
PostPosted: August 16th, 2012, 15:42
Depends on the purpose. For a stiction job for example stick it on DDI and after watching it for a few mins just walk away. However, for everything else I think DE is way more efficient. I use my DDI more for wiping drives than for imaging actually...
PostPosted: August 16th, 2012, 15:47
Nick_CT, i really disagree with you here
spending too much on this (WIPE), is really a waste of $$$$
whatever is the case with you,,, good luck with it :wink:
PostPosted: August 16th, 2012, 15:52
You're missing my point. I use it wipe more than to image, because I prefer to image with DE for most cases. DDI is a great imager, but after a head swap on a drive with say media damage, I never put it on DDI, only on DE and pick off what I need. I've tried using the network add-in and became frustrated with it and haven't tried again as DE does all of what I want. I'm saying that DDI is a great tool for a lot of applications, but I find the efficiency of DE unbeatable.
If I could choose 5 tools, I'd have 4x DE and 1x DDI. Sometimes you'll find certain drives just won't work on DDI. Stick them into DE and no problems. DE is more versatile in my opinion.
We'll agree to disagree I don't mind, what works for me works for me.
Enjoy your DDI.
PostPosted: August 16th, 2012, 15:54
einstein9 wrote:
Guys,
Any reason you're using "clone" mode rather than "imaging" on that screen? :-)
PostPosted: August 16th, 2012, 15:58
DDI and DE both have their pros and cons, like people are generally saying.
It very much depends on the type/make of drive and the original problem as to which I use for any given job.
Luckily I have several DE machines, and several DDI so can pick & choose :-)
Currently playing with a new DDI4 that came today with all the trimmings, including some new interesting gadgetry and software updates. Very impressed so far!
PostPosted: August 16th, 2012, 16:05
pcimage wrote:
einstein9 wrote:
Guys,
Well, just got it few days back, and was testing n comparing it with my DE and how they treat bads
Answering your Q about Why DDI? why not DE
Well, i recently getting many many cases of most DB files with MANY bads in hdd which i cannot work around with DE
so for many bads on big DB file you either loose DB RECORDS or damaged DB
in addition, the main other reason is cloning Smartware HDD`s with bad/weak condition heads
those are the most 2 reasons of buying it...
and sure 4 is much better/faster than 3 (after asking many people who used both btw)
:wink:
PostPosted: August 17th, 2012, 6:26
I can't see how DDI is better than DE when you can configure DE any way you want. Maybe there is a difference in speed? DE can clone disks not even detected such as Seagate, Hitachi etc.
Saying that I've never used DDI but I still can't see how it can do things better.
For the money involved, I would rather pay the extra for PC3000 and DE.
PostPosted: August 17th, 2012, 16:06
as a reply for your comment here i would say:
Every Screw Driver has a purpose... all depends...
and this is the key...
good luck :wink:
PostPosted: August 17th, 2012, 16:08
Any initial thoughts on v3 vs v4?
PostPosted: August 17th, 2012, 19:59
V4 kicks butt.
We've achieved over 100 MB/sec.
http://www.datasaversllc.com
PostPosted: August 18th, 2012, 7:16
It IS quicker, no doubt.
PostPosted: August 18th, 2012, 7:19
I'm thinking of getting one, Does the target drive connect to esata or sata? Can you guys take some pics showing the connections? :)
PostPosted: August 19th, 2012, 4:03
Esata connection for target
PostPosted: August 19th, 2012, 12:48
Not to downplay DDI in any way, because I have to admit that is a great product based on my own experience with ver. 3, but I have used and still use eSATA occasionally for higher speeds over USB 2.0 for data transfer to externals and at times eSATA based devices loose connectivity with the system. Really hope that will not be an issue with ver. 4.
SATA for destination drive, hardly ever is a problem.
PostPosted: August 22nd, 2012, 9:36
It is really Amazing what DDI is capable of specially in PHASE-2
again, worth every single cent.... 100/10
Users browsing this forum: No registered users and 111 guests
