 Post subject: ROM ver. Identifier - v1.0
PostPosted: August 23rd, 2012, 14:35
for some of us here it might be useless but really i came up with this idea since am too lazy
to check it in Winhex and asked my Developers (Partners) to do it and save some of my time here
i would like to share it with you guys here...
next release will be even much better
Thank you forum members/Admins
:wink: :wink:
:yayaya:
file can be downloaded from here: http://files.hddguru.com/download/Other ... dentifier/
 Post subject: Re: ROM ver. Identifier - v1.0
PostPosted: August 23rd, 2012, 15:08
From what I see it's .Net app (that probably won't work in DOS mode as specified) and it support some WD flashes
PostPosted: August 23rd, 2012, 15:26
it should work my dear if you have .net 2.0 or later
have a look
PostPosted: August 23rd, 2012, 15:34
it definitely should, in command prompt, you probably meant that
I wonder what's the practical value of this program
It returns internal version of the first found module with ROYL header, I might be missing something here but I cannot come with any idea where I could actually use that kind of information
PostPosted: August 23rd, 2012, 15:42
Just in case somebody wants to share another opinion on the code
namespace GetID
    using System;
    using System.IO;
    using System.Runtime.InteropServices;
    using System.Text;
    internal class Program
        private static byte[] _RoylCode = Encoding.ASCII.GetBytes("ROYL");
        private static void FindIdInFile(string path)
            long num;
            string str;
            if (FindIdInFile(path, out num, out str))
                Console.WriteLine(string.Concat(new object[] { "Found ID at offset ", num, " [0x", num.ToString("X"), "]: ", str }));
            else
                Console.WriteLine("ID not found!");
        private static bool FindIdInFile(string path, out long offset, out string id)
            using (FileStream stream = File.OpenRead(path))
                while (stream.CanRead)
                    if (((stream.ReadByte() == _RoylCode[0]) && (stream.ReadByte() == _RoylCode[1])) && ((stream.ReadByte() == _RoylCode[2]) && (stream.ReadByte() == _RoylCode[3])))
                        offset = stream.Seek(12L, SeekOrigin.Current);
                        byte[] buffer = new byte[8];
                        if (stream.Read(buffer, 0, 8) == 8)
                            id = Encoding.ASCII.GetString(buffer);
                            return true;
                offset = -1L;
                id = null;
                return false;
        private static void Main(string[] args)
            if (args.Length < 1)
                Console.WriteLine("No file path specified.");
                Environment.ExitCode = -1;
            else
                string path = args[0];
                if (path.StartsWith("\"") && path.EndsWith("\""))
                    path = path.Substring(1, path.Length - 2);
                if (!File.Exists(path))
                    Console.WriteLine("'" + args[0] + "' is not a valid file path.");
                else
                    FindIdInFile(args[0]);
PostPosted: August 23rd, 2012, 15:43
Well, for me because am too lazy searching in Winhex i asked for it, anyway, this is the prototype the new one will be in GUI
drag-n-drop with the same function.
for WHY or whats the use of it?
as i said, am too lazy looking, also might help newbies here, or anyone wanted fast results of it.
not bad idea i guess?
PostPosted: August 23rd, 2012, 15:44
Well, now I feel like I'm definitely missing something
How one could use that ID?
PostPosted: August 23rd, 2012, 15:51
Oh, I think I figured that out
You need add additional check for Module ID. The module ID you are looking for is 4F :)
Because on the picture you are getting it from module 0A :)
PostPosted: August 23rd, 2012, 15:59
Hummm :row: :smokers: :druunk: heheheh (this is the intro.. - just kidding)
well for some newbies here who ask for FW resources sometimes, they always start with hdd model # & SN .... and so on
till someone here replies back asking for ROM ver. which again newbies need some time to get used to it
and ask the direct question providing model + ROM ver. in case if PCB is totally dead (for example w/o U12)
or if people like ME for example, too lazy to look into HEX to find match donors (which always happens really all the time)
i have a backup of many resources in 2 NAS for the most well known tools collected/bought it during my DR
some of them are ROM`s which again too lazy to go through it and save it in a way which is easy to find it later.
those are some of the reasons why i needed it, and shared it here...
:row: :smokers: :druunk: heheheh (this is the end.. - just kidding)
PostPosted: August 23rd, 2012, 16:02
yes, for the ROM revision you need to add Module ID check
Because right now it doesn't work
PostPosted: August 23rd, 2012, 16:03
oooh, many replies from you while am writing.... ehehhehe
about the picture, i was refering to the app. since u said not working
and the code is very simple, nothing hidden, any programmer can do it my dear... :wink:
PostPosted: August 23rd, 2012, 16:04
Doomer
http://lel1996stardollblog.files.wordpr ... -small.jpg
i cannot reply to 3 posts @ the same time
give me a break.... heheh
PostPosted: August 23rd, 2012, 16:08
Doomer's (correct) point is that it is not returning the correct answer
PostPosted: August 23rd, 2012, 16:17
i guess guys and you too Doomer are right
will ask my developer about that
hehehe
thnx for the feedback
did u find this useful as an idea? or not?
PostPosted: August 23rd, 2012, 18:18
IDK, if you have an ability to read ROM, you shouldn't have questions about its version
PostPosted: November 3rd, 2012, 5:53
Updated v2 with GUI
can be downloaded in files section: http://files.hddguru.com/download/Other ... dentifier/
Thank you
