 Post subject: Converting WD 2.5 500GB USB 3.0 to SATA
PostPosted: August 23rd, 2012, 20:12
Hi all,
I want to modify the usb only connector which come on 2.5 drive WD 500GB WD5000BMVW-11AMCS0 unfortunatlly I can't find on the pcb the chips which I have to remove. On the usb 2.0 the chips to remove are: C13, C18, C31, C33 but those chips can't be find on the PCB of the usb 3.0 drive.
As it seems to me and by the location only of the chips I can guess that the right chips to remove are: C92, C93, C91, C90.
What do you think?
Are those the right chips to be remove?
Best Regards,
 Post subject: Re: Converting WD 2.5 500GB USB 3.0 to SATA
PostPosted: August 24th, 2012, 8:07
Scorpion wrote:
Hi all,
What do you think?
Best Regards,
Can you post hi quality pics of both sides of the PCB?
Loki
PostPosted: August 24th, 2012, 8:21
It is easier to find a SATA PCB with the same controller and then just move the U12...or just connect via terminal in PC3000.
Users browsing this forum: Bing [Bot], Google [Bot], napalm_atx and 88 guests
