 Post subject: 2TB Sadle G6 strange behavior
PostPosted: August 27th, 2012, 14:30
Dear Experts
i got this WD 2TB case where all modules are OK, heads are OK everything is OK
Except i cannot access any sector NONE OF THEM.
- tried hotswap to even see any sector (none same issue) and my donor is luckily same ROM ver. same Family same HM
- tried another pcb (same issue)
attached is the Log
Hardware modules checking
SA structure test
i got so sick of it really, never had such a case like that.
Client said: was working, and power went off, then hdd did not work after
any clues here....?
thank you
Reports.rar [15.46 KiB]
Downloaded 607 times
 Post subject: Re: 2TB Sadle G6 strange behavior
PostPosted: August 27th, 2012, 15:58
But how sure are you that all heads are OK....
Data Recovery Cape Town
PostPosted: August 27th, 2012, 16:01
:idea:
Bingo! :-)
PostPosted: August 27th, 2012, 16:08
correct me if i wrong, there is no tool can tell you definitely if the head is totally ok even if the head can read & can write
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: August 27th, 2012, 19:55
You don't need a tool for automatic testing of each head, as there are ways to check if they are working fine or not.
Also, from my experience, Sadle drives are very tricky.
PostPosted: August 28th, 2012, 1:23
At least one of the heads is weak/bad......
There is....It is the tool you use to exchange heads...That tool will "tell" you if the heads were really ok or not :) ...
Correct.
www.datasave.ro
PostPosted: August 28th, 2012, 4:03
thank you guys for the comments here
Heads been tested with 3 Diff. tools with the same result.
anyway, i got some PM`s here will try it and see how it goes...
Thank you all :roll:
PostPosted: August 28th, 2012, 5:43
I'm interested to know what tools/methods you have used to test heads with, because from my experience the symptoms you are having are normally indicative of a bad head which could be pinpointed very quickly in 3K.
PostPosted: August 28th, 2012, 11:28
Try to edit headmap in ram and soft rest, then modify to original headmap again.
All sectors should be accessible but the weak heads.
8)
PostPosted: August 28th, 2012, 13:09
8)
Do you think he didn't try that yet? Like was said before , this drives are tricky , need another method to play with them.
I am pretty sure some head is "weak" .
Angel Data Recovery
PostPosted: August 28th, 2012, 14:19
Very easy to swap heads with these guys.
PostPosted: August 28th, 2012, 14:33
Agree, perhaps the easiest step of the recovery.
PostPosted: September 1st, 2012, 13:18
Case Done, luckily.... was the 1st. time with me with the help of the Unknown PM guy....
if he wishes, i can reveal his ID, if not, then will be underground like the others here..
Many thanks for this TIP, i never tried it, specially with my Lovely Tool.
:agree: :druunk: :smokers:
PostPosted: September 1st, 2012, 21:45
einstein9 wrote:
Dear Experts
attached is the Log
SA structure test
any clues here....?
thank you
I have same problem how to solve it ?
thanks
PostPosted: September 2nd, 2012, 6:18
8)
Yes. I do. Of course we know it is because of Weak head(s). I used to clone the data with good heads then swap heads to clone the last data on weak head. If he had tested it, I think he could get partial data from this driver and wouldn't ask it.
PostPosted: September 2nd, 2012, 8:56
book14 wrote:
8)
with all my respect, YOU DON`T
i`ve tried almost everything, and as Dr.Kiev said since i know him very well , he knows how do i think..
and this is Sadle G6 issue, which was my 1st. case problem facing here.
PostPosted: September 2nd, 2012, 9:22
einstein9 wrote:
book14 wrote:
DR-Kiev wrote:
Sorry for I had doubted you have tried.
Actually, this is a common sympton for Sadle G6. Both the Capacity and ID are correct , no clicking sound.
All modules are okay ( the 2E and 6F is usually bad), but the sectors are not accessable even clear module32 or fix slow.
And I am sure if you swap headmap to eg (2 3 3 3 3 3) then soft-reset and change head map to 2 3 4 5 6 7,
you can access the data, and will find a lot of bad sectors on certain head. The head(s) is(are) weak.
PostPosted: September 2nd, 2012, 9:30
did not work..
and thnx for the tip my dear
PostPosted: September 2nd, 2012, 14:45
The question is, was a head swap required...
PostPosted: September 3rd, 2012, 5:26
A, NO..
:wink:
Users browsing this forum: fouad19764, Google [Bot] and 177 guests
