 Post subject: Toshiba canvio 2tb 2,5' usb 3.0 SERIOUS PROBLEM
PostPosted: August 28th, 2012, 8:55
Hi, I've a toshiba canvio 2tb 2,5' usb 3.0.
It doesn't work. I try to erase partition, all is ok. I try to format, stop after some minutes with "impossible to format" from windows xp/7/ manage disk/partition manager.
Toshiba doesn't provide tool for this hd.
If I try to create and format a partition with around 19gb, all is ok: partitioned and formatted.
Biggest partition is impossible.
HD Tune Pro says there are some bad sector. Error check stop after 19gb.
I try hdd low level format, and it stop at sector 39,264,128. All is ok until that sector, after led on hard disk stop, tool freeze.
All the test with usb 2.0.
Anyone can help me?
thanks
 Post subject: Re: Toshiba canvio 2tb 2,5' usb 3.0 SERIOUS PROBLEM
PostPosted: August 28th, 2012, 10:18
Isn't your drive under warranty?
If it is, I would use it.
PostPosted: August 28th, 2012, 14:08
Fake?
EBay china purchase?
PostPosted: August 28th, 2012, 16:27
@pcimage,
pcimage wrote:
Fake?
Good point - I have not seen a Toshiba 2.5" 2TB disk drive...
@diabolique1984,
Please give the history of this drive.
- Where & when did you buy it?
- Does it have a warranty from that supplier, to allow you to return the drive?
- How much data have you stored on it successfully?
- Why were you trying to format it - what problem happened before you decided to do that?
- In WinXP using the options (I think): Control Panel -> System -> Hardware -> Device Manager -> Disk Drives (or any other equivalent technique which you prefer), what disk drive model number is shown for this Toshiba drive?
PostPosted: August 29th, 2012, 4:02
Hehe, another one like this:
or this:
PostPosted: August 29th, 2012, 4:50
Mi sa che trattasi di SOLA.... 8)
I have a feeling it is a FAKE..... 8)
PostPosted: August 29th, 2012, 5:30
100% a fake.
PostPosted: August 29th, 2012, 6:03
The best I got was a client bringing a 800Gb USB Pen drive.
PostPosted: August 29th, 2012, 7:20
The size of a Coke can maybe ? :mrgreen:
I wonder how people fall into these scams...
PostPosted: August 29th, 2012, 7:43
I think it's a bit normal for non tech people.
They don't have idea of how much can be the capacity of a pen drive.
Also, they don't think much.
Here there is some wisdom words, something like this: When the alms (charity) is too much, the poor man always suspects.
Users browsing this forum: Google [Bot] and 369 guests
