 Post subject: Help for a diagnostic, Hitachi HDT721010SLA360 1TB HDD
PostPosted: August 29th, 2012, 19:54
Hi, I'm a newbie here looking for help!
I have a Hitachi HDT721010SLA360 1TB HDD (P/N W: 0A38116) that recently stopped working. At first, I had problems recognizing it in linux, so I switched to windows where it worked for a few minutes then stopped working. Now it seems to spin up then make a low pitched click sound at a slow frequency. It is not "seen" by either windows or linux using two different enclosures.
I've read that thread: need-pcb-hitachi-1tb-hdd-hdt721010sla360-0a38016-t18870.html
It was in a USB enclosure. I tested the voltage on the enclosure power supply and on the sata power rail it provides and everything seems fine. I also tested the "L14" 12V TVS diode with a multimeter and it's not shorted (R > 200\ohm).
Here's a video of it spinning up, you can hear the sound it makes, I have not found a comparable sound online:
http://youtu.be/tkyVSoVJfwU
Here are pictures of the front and bottom, for any info:
http://img706.imageshack.us/img706/8480/imag1572v.jpg
http://img689.imageshack.us/img689/9239/imag1571.jpg
I really wanna retrieve the data on this drive without paying too much, so any safe (non freezer related) advice to diagnose it are welcome. I'm also looking for a replacement PCB to test it out. I have access to a cleanroom (don't know which class) if the fix isn't too complicated, otherwise I'd like to avoid this option.
Thank you very much!
FG
 Post subject: Re: Help for a diagnostic, Hitachi HDT721010SLA360 1TB HDD
PostPosted: August 30th, 2012, 20:21
Was the drive dropped? Or suspicious that it may have been?
PostPosted: August 31st, 2012, 3:35
Sounds more like a heads-related issue rather than PCB.
PostPosted: August 31st, 2012, 17:22
And this ones very prone to head crashes IMHO.
PostPosted: September 1st, 2012, 6:01
FG
99% been dropped/knocked. Doesn't take a lot :-(
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 284 guests
