 Post subject: 7200.11 bsy problem insists
PostPosted: August 24th, 2012, 5:09
i got a Seagate 750Gb 7200.11 which wasn't recognised because of the bug. i tried to fix it and now it has the zero problem. when i go to the terminal to fix the zero capacity problem, i takes about 8-9 minutes to complete the procedure. the zero capacity problem insist.
any suggestions?
thank you in advance
 Post subject: Re: 7200.11 bsy problem insists
PostPosted: August 24th, 2012, 5:24
You try ESLIP mode to get access?
PostPosted: August 24th, 2012, 6:45
hi,
i don't think switching from "ASCII Diagnostic Mode" to "ESLIP" will fix your LBA0 problem.
Maybe useful to know exactly which commands you sent through com port from the beginning and the hdd reply, if you saved the log should be even better.
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: August 24th, 2012, 6:48
I agree it wont fix it, but some level of access to the data may be possible using it assuming it is translator related error...
PostPosted: August 24th, 2012, 15:24
Agree.
Have had success with this in the past, when translator regens don't "stick". :P
PostPosted: August 29th, 2012, 13:52
i tried to find more info about ESLIP mode but couldn't find. can you give me some more details or is there anywhere on the internet where i can find?
how about changing the pcb and changing the Rom chip. will that have a result?
thank you
PostPosted: August 29th, 2012, 16:26
The problem is not with the PCB, so there is no need to swap it.
PostPosted: August 29th, 2012, 16:47
Are you 100% sure that the source of the symptoms isn't something else, such as bad heads or media damage?
PostPosted: August 30th, 2012, 14:06
7200.11 when there is damage with heads, it speed down after trying to initialize. my drive initialises correct, shows M/N, S/N and LBA 0.
when i first got it in my hands, it wasn't recognised. after clearing the smart shows up with LBA 0. tried several times to fix that. it takes up to 8-9 minutes to finish the procedure, but still no result.
PostPosted: August 30th, 2012, 14:46
I agree with Luke, you should perhaps check that the cause of the symptoms is not actually a physical one such as a bad head. The last 2 cases I've had of BSY and 0 LBA .11 drives were due to a bad head.
Data Recovery Cape Town
PostPosted: August 31st, 2012, 5:02
:good:
I bet there is a LED on terminal too :mrgreen:
PostPosted: September 1st, 2012, 3:09
i will change heads and see how it goes.
thanks for your help
Users browsing this forum: No registered users and 296 guests
