 Post subject: Hitachi HDT7210505LA360 - 0A29991 - BA3263
PostPosted: August 30th, 2012, 12:38
Hey Guys and Gals, I am on a mission to find said PCB for a friend, She has the machine in for repair and they have told her the PCB is shot, so I said I would try and help her find a replacement.
P/N:0A29991
MLC:BA3263
Any help greatly appreciated.
 Post subject: Re: Hitachi HDT7210505LA360 - 0A29991 - BA3263
PostPosted: August 30th, 2012, 14:17
Please post a good quality photo.
PostPosted: August 30th, 2012, 17:48
The 2 first rows on the white Pcb-sticker should match, to make a good donor Pcb...don't forget to move the adaptive data from the old pcb.
Cheers
Bosse
http://www.rescue-it.se
PostPosted: August 31st, 2012, 17:30
Have you tried the correct area inside of the forum for searching parts?
A lot of vendors are there replying to posts. Also, you can try ebay, it's a good source.
But be aware that a simple PCB swap will not help you to recover the data.
PostPosted: August 31st, 2012, 17:39
Good advice
PostPosted: September 5th, 2012, 18:20
Right!!! Firstly thank you for taking the time to help. :wink:
@ pcimage - I shall ask her to mail a photo.
@ mr_spokk - I thought the part# and MLC were enough?
@ dmarques, not yet no.
Any further "pointers" would be greatly appreciated.
Thanks again.
PostPosted: September 5th, 2012, 20:10
Personally I'm concerned about trusting the previous diagnosis, without getting further information.
Did she (or you) get any further details about exactly which part of the PCB is "shot", in their opinion? Unfortunately we have seen people post here, where a PC repairer has mis-diagnosed an internal drive fault as being a PCB problem. :(
Therefore I suggest that you post the actual symptoms of the drive - how exactly is the drive behaving? (e.g. does it spin-up when power is applied? does it stay spinning? any abnormal noises like clicking? is the drive make / model / capacity reported correctly in the BIOS disk setup screen? was this previously an external drive? etc. etc.), and also give a brief history of what happened just before this problem started, as well as a list of what tests and diagnosis has been done already, with a list of the results of each test.
Just a suggestion...
PostPosted: September 6th, 2012, 2:41
It depends on what you need to do with the drive...but for Pcb to work you need to match the first two rows on the original Pcb's sticker.
Cheers
Users browsing this forum: Google [Bot], quinkq and 208 guests
