 Post subject: Hitachi Hdd problem
PostPosted: December 1st, 2010, 7:47
Hi !
Sorry for bad English.
I have HDD Hitachi HDT725032VLA360
Firmware V54OA73A
The hard work fine. Evrithing in SMART is OK.The problem is , when I turn off computer ,then set the power on,HDD is missing.In BIOS is only shows firmw. :
Primary IDE chanel : V54OA73A
Must be:
Primary IDE chanel :Hitachi HDT725032VLA360;V54OA73A.
And Windows not start , - no HDD.
I have "Hirens Boot CD" , but all programs in "HDD Tools" says "no hdd".Only "Gateway GwScan" wiew my hdd ,then i reboot , and everything is fine.
If I only restart the computer , is no problem.
Wheare is the problem ?
P.S.
I downoad correct firmware - http://files.hddguru.com/download/PC-30 ... e/Hitachi/
Flashing the hdd ,is resolve main problem ?
If the answer is YES , please for links with correct flasher , and manual (instruction).
Thanks.
 Post subject: Re: Hitachi Hdd problem
PostPosted: December 1st, 2010, 8:32
It appears that your drive is Powering Up In Standby (PUIS).
Here is one solution:
http://groups.google.com/group/comp.sys ... f0feb49f0c
PostPosted: December 1st, 2010, 9:48
Thanks man...
Finaly i resolve main problem.
Thank You
PostPosted: September 8th, 2012, 8:00
Recently my hdd Hitachi was sounding as "click-click-click..." (I may send you a mp3- recording of this sound) and didn't determined by the OS at the same time, while I was leaving the PC turned on for a day, for example, to upload media content, or defragmentation.
shutdowning the PC and booting PC again solves the problem, but the problem was reappeared from booting to booting. I've check the hdd by program HD Tune Pro 5.00 - it shows "All is OK".
See the SMART:
HD Tune Pro: Hitachi HDT725032VLA360 Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 100 100 16 0 ok
(02) Throughput Performance 100 100 50 0 ok
(03) Spin Up Time 111 111 24 21758291 ok
(04) Start/Stop Count 100 100 0 1093 ok
(05) Reallocated Sector Count 100 100 5 0 ok
(07) Seek Error Rate 100 100 67 0 ok
(08) Seek Time Performance 100 100 20 0 ok
(09) Power On Hours Count 100 100 0 3397 ok
(0A) Spin Retry Count 100 100 60 0 ok
(0C) Power Cycle Count 100 100 0 668 ok
(C0) Unsafe Shutdown Count 100 100 0 1185 ok
(C1) Load Cycle Count 100 100 0 1185 ok
(C2) Temperature 171 171 0 524323 ok
(C4) Reallocated Event Count 100 100 0 0 ok
(C5) Current Pending Sector 100 100 0 0 ok
(C6) Offline Uncorrectable 100 100 0 0 ok
(C7) Ultra DMA CRC Error Count 200 253 0 0 ok
Then I set the Enabled (was Disabled as default) parameter "HDD S.M.A.R.T. Campability" in CMOS for both hdd-drives, connected to PC.
After that the hard drive Hitachi began to work normally and more quite for 6 months, but after that the problem has returned. I've removed bottom electric plate and cleaned it with an eraser. Have changed the SATA cables and connection ports - No results. I've plugged a new Seagate for backup to the same port - it operate normally. Should I check my troubleshutting Hitachy by MHDD? On what parameters I should pay attention in this case?
My motherboard - Gigabyte GA-P35C-DS3R rev 1.1. BIOS ver F2, I have n't updated its since 2007. Should I Update the BIOS of mb or Hdd's?
PostPosted: September 8th, 2012, 8:05
Name of drive Hitachi HDT725032VLA360 (320 GB). It was bought in 2007. But worked since 2010. operating time of 3300 hours use. resource? Maybe less of 50%
PostPosted: September 8th, 2012, 8:07
Can anybody help me?
PostPosted: September 8th, 2012, 8:14
now to snapping added short rarely peeps...
Users browsing this forum: Google [Bot] and 226 guests
