 Post subject: VP-298 programmer worth somthing?
PostPosted: September 11th, 2012, 21:03
Hi all,
Is VP-298 programmer worth something?
It cost 120USD.
Would be happy to gather your opinions.
 Post subject: Re: VP-298 programmer worth somthing?
PostPosted: September 12th, 2012, 4:30
VP or any other when you think about it only think about the following:
How many chip/ic`s does it support?
some support 10k other 200k (types/models)
they all the same for me unless you know for what purpose you wanted it for?
and the sockets as well their prices as an accessories and if you need them or not
sometimes cheap stuff will do the job, but later on you MIGHT need the Pro. one
all depends
and good luck
Suggest, Ask member Eric here form china, might give you few models/examples/prices
PostPosted: September 12th, 2012, 7:55
the question you have to answer first , what will you use it for ?
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: September 14th, 2012, 8:43
The use is for reading and writing rom/nv-ram chips from all the hard drives vendor.
Instead of soldering out the chips to the donor pcbs.
I talked with the seller from drivestar and he said that it will be a good match for the following adaptor:
http://www.drivestar.biz/adapter-sop8-s ... p-661.html
This adaptor + the programmer will save me the use of SMT station (which I also have but looking for easier work..)
PostPosted: September 14th, 2012, 17:05
DIY programmers:
http://www.kmitl.ac.th/~kswichit/SPI_Pgm/SPI-Pgm37.html
Pony Prog http://www.lancos.com/prog.html
PostPosted: September 15th, 2012, 5:39
for what you mention , VP-298 from wellon is good choice
Tawfeek Mokhtar
Users browsing this forum: Majestic-12 [Bot] and 60 guests
