 Post subject: ST9160823AS stay busy, preamp message
PostPosted: September 19th, 2012, 10:33
This HDD can be indentify one time. But today, we can't indentify this HDD and we have this termnal logs.
Hdd stay allways busy.
We have change HSA => exactly same problem.
Any idea for resolve this problem ?
Reset
4096k x 16 DRAM
GALILEO - 1_Disk S-0E 12-07-07_17:09
HM SFI
(P)
Preamp Sent Greater than Max Allowed Bias (4F-0D)
Preamp Sent Greater than Max Allowed Bias (4D-0D)
Not Interface Age!
DiskAccess ReadSector EC=47 at ffffffff.00.0000
INVALID Cert Disk Code - ROM Resident Revision Required: AAZ2Y0
Command Inactive - No VALID Cert Code Detected
T>
 Post subject: Re: ST9160823AS stay busy, preamp message
PostPosted: September 19th, 2012, 15:12
Someone has played with the drive and... touched the 'untouchable'. Or the fw is screwed to death. Or pcb is non native. Or a mix of all these options. Latest idea : bad heads , but math doesn't add up with this log.
PostPosted: September 20th, 2012, 3:36
What do you mean by the HDD was identified one time?
PostPosted: September 20th, 2012, 5:11
Did you try to restore age to 50? Also looks like H0 has some problems.
PostPosted: September 20th, 2012, 10:40
...and then why it it was not 50? 8)
Users browsing this forum: Google [Bot] and 226 guests
