Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Western Digital Donor Matching details
PostPosted: September 26th, 2012, 1:21
can someone assist me to know the donor HDD matching details for Western Digital?
What should i check in DCM?
 Post subject: Re: Western Digital Donor Matching details
PostPosted: September 26th, 2012, 1:24
Donor for what? Heads? PCB?
DCM is not important for either.
http://www.datasaversllc.com
PostPosted: September 26th, 2012, 1:49
Hi Jono, Am glad you choose to try and help.....
Please assist me in knowing what i should check then...
Is the date important? Country of origin? Model no including even after the hyphen?
PostPosted: September 26th, 2012, 1:57
Hi, all that info has been brought up many times...use the search button at fist.
http://www.rescue-it.se
PostPosted: September 26th, 2012, 1:59
PostPosted: September 26th, 2012, 2:01
mr_spokk, No harm in telling it again, pls...
PostPosted: September 26th, 2012, 2:38
You still haven't said what part you need, heads or PCB??
PostPosted: September 26th, 2012, 3:45
pcimage,
Hi
its several cases, some need heads and some PCB;
could you please treat each case differently?
PostPosted: September 26th, 2012, 5:53
Theres no harm in you using the search facility either :wink:
http://www.donordrives.com/hard-drive-p ... swap-match
Loki
PostPosted: September 26th, 2012, 9:22
For heads, same drive family, heads map, and microjogs fairly close.
PostPosted: October 2nd, 2012, 3:03
Hi, thanks for your effort to assist.
PostPosted: October 2nd, 2012, 7:26
i begin to believe in Wd heads swap , the rule here that there is no rule
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: October 2nd, 2012, 8:12
What was your take initially?
JACK.
PostPosted: October 2nd, 2012, 8:19
JACK.
what he means sometimes BASED on your work (experience) you end up with a RULE (your own rule), seeing others posts SOMETIMES breaks 1 or 2 or your TESTED RULES
which ends up to: No Rule Based on your Rules..... heheheh confusing issue sometimes..
PostPosted: October 2nd, 2012, 8:33
Hi, you guys....make me wonder at times.
No one ever comes out so straight....but i know why.....no one is ready to trade His/her skills with others as it were...
Looking forward for a day when people will share info freely.
Jack.
PostPosted: October 2nd, 2012, 9:23
@ Jack: einstein9 and tawfeek said it best.
Once you think you have a "rule" figured out, you do a head swap that breaks it.
But there are some criteria that increase the probabilities of success, and I shared the ones that work for me.
What do you want? Something case in iron or stone? I don't think it exists . . . there are too many exceptions.
PostPosted: October 2nd, 2012, 10:07
@ Jono glad you tried to help,But the info you provided was shallow....wish you tried to expound a little.
Share your info with no hard feelings.
PostPosted: October 2nd, 2012, 10:38
Dear Jack,
I can give you a small TIP on how things are going either HERE (forum) or maybe in your LIFE (in general)
Seeking Advices/2nd. Opinions from DR`s (Doctors) costs
there are CHEAP (5 cents) Advices - useless
there are DAMN EXPENSIVE Doctors (who spent AGES of experience) - costs here.
so for this case scenario, DO NOT EXPECT Free Advices from those Damn Expensive Doctors, UNLESS they see its a normal thing to know/share
this applies to all (in my life) - you should PAY your SCHOOL fee`s - as those Doctors PAID ALREADY THEIRS
this is what i have for you here, and good luck
but
Remember something for HERE:
when people HERE used to YOU, and they FEEL you know GOOD, expect many PRIVATE PM`s for TIPS/Advices
but do not SPREAD IT.
good luck
PostPosted: October 2nd, 2012, 11:10
I've found through years of experimentation and practice on old drives that you can have some really weird situations where two drives should not be compatible at all, but the heads end up working perfectly. I've highlighted a couple of cases on this site, and others I haven't. I will say that for the most part, everything I thought I knew about drive compatibility 10 years ago was completely thrown out the window. :lol:
PostPosted: October 2nd, 2012, 11:30
Wait a minute...
You're asking for WD donors and you show a Hitachi drive??
Which one is it??
ACELab partner
Users browsing this forum: No registered users and 72 guests
