 Post subject: Head-map imaging on Seagate U4
PostPosted: September 26th, 2012, 16:04
Does anybody know how to image an old seagate U4 by selective heads (hdd model is ST38421A a old 8,4GB 4 heads)
pc3K,DC,DDI looks can't do this task.
 Post subject: Re: Head-map imaging on Seagate U4
PostPosted: September 28th, 2012, 4:05
Ma scusa non fai prima a ripararlo ? A meno che non ci sia problemi di superficie io non ci penserei su due volte. O non trovi un donatore ?
Isn't it easier to fix the drive ? Unless there's media problem I wouldn't think twice about it. Or is the problem lack of donor ?
PostPosted: September 28th, 2012, 4:19
BlackST wrote:
Unless there's media problem ..
It's a Media Problem, already head swapped twice, same result.Two platters are demaged or heads there can't find SERVO and do not let drive read more than few sectors without hang the drive ( or go to busy, or motor spin down)
At Power ON, drive ID correctly with difficoulties and rumors, i can reach sectors readable but when i ask a sector of one head demaged, drive hang. without head map nothing to do.
Users browsing this forum: Google [Bot] and 86 guests
