 Post subject: Recover data from WD2500JS
PostPosted: September 29th, 2012, 17:13
Hi gurus,
My WD2500JS HD died.
It spins, clicks 3 times and stops spinning (2 tries).
The device is also not detected by the BIOS.
I replaced the PCB taken one from another identical (working) HD, but it didn't work.
Here is a video:
http://www.youtube.com/watch?v=hLG6Y2MCrNk
The other HD is working fine with the PCB taken from the broken HD.
Thus, may I assume the U12 chip has a similar calibration?
Should I try replacing the U12 chip anyway (even if the disk is spinning)?
What else may I try to recover the data?
 Post subject: Re: Recover data from WD2500JS
PostPosted: September 29th, 2012, 17:47
Nothing, as the problem is not the pcb.
PostPosted: September 30th, 2012, 6:10
Agree with BlackST
You have done all the DIY work you can on this.
Users browsing this forum: Google [Bot] and 273 guests
