 Post subject: Galaxy2D displayng corrupt ID and SN and datas
PostPosted: October 11th, 2012, 12:09
Got this ST3500830ACE,
can ID and read sectors (only in pio mode)
but cloning drive also in raw recovery i have all data as "garbage".
Looks like a general corruption, of SA and DA,
anyone faced this?
 Post subject: Re: Galaxy2D displayng corrupt ID and SN and datas
Check pins / cable
PostPosted: October 11th, 2012, 12:20
Tryed to clean contacts, tryed 2 pc3000 machine, same results.
Guessing:
- rom corrupted
- pcb faulty
- SA corrupted
- heads dirty
PostPosted: October 11th, 2012, 12:22
Most likely PCB.
Good luck
PostPosted: October 11th, 2012, 16:31
Anything in terminal output?
Data Recovery Cape Town
PostPosted: October 11th, 2012, 16:42
Terminal output is perfect.
Tmrw will diagnose pcb..
PostPosted: October 11th, 2012, 17:04
I would bet its a bad PCB too.
Or at least a dodgy SATA connection.
PostPosted: October 11th, 2012, 17:08
This is IDE, right? So, problem with one of the pins or solder joint to PCB... either way replacing PCB is easier if you have one on hand
PostPosted: October 12th, 2012, 3:22
I had the same problem. It took me 2 hours to realize this was a connections/connector issue. I saw light when I connected another drive and saw that hieroglyphic on drive's ID. It turned out to be my IDE -> Sata converter.
PostPosted: October 22nd, 2012, 9:07
Data recovered,happy customer,
ROM corrupted or PCB faulty was the issue.
PostPosted: October 22nd, 2012, 14:39
Must been Pcb, as this model needs the ROM to be transferred as well.
http://www.rescue-it.se
PostPosted: October 22nd, 2012, 16:11
AISI, it was obviously an issue with the IDE interface.
The first clue is the fact that every second character in the model number is corrupt. The IDE bus is 16 bits wide, and each character is stored in 8 bits ...
Other clues include the number of logical sectors, ie ...
32831 = 0x803F
This number should be 0x003F, so clearly there is a single stuck bit.
You could then refer to the IDE pinout to identify the failing bit:
http://pinouts.ru/HD/IdeInternal_pinout.shtml
ISTM that DD15 (pin#18) would have been faulty. I would have checked the soldering, plus the associated resistor.
Users browsing this forum: Google [Bot] and 75 guests
