 Post subject: WD3200BMVV - 11A1PSO
PostPosted: October 12th, 2012, 8:26
Hi.
I need help with recovering data from a WD3200BMVV USB.
I know there are methods to convert USB to SATA for these ones, but haven't found information applicable for this drive.
Drive will not be sent and recovery will be made using tools in my facility. Have access to IR Solder, Hot Air Solder, PC3K, Atola Insight, Flowhood.
Advice that leads to sucessful revovery will be rewarded with €.
This is a study project for my own education, no important customer data on drive.
If you don't want to help your competitor i can inform you that i only do business in Denmark.
 Post subject: Re: WD3200BMVV - 11A1PSO
PostPosted: October 12th, 2012, 8:57
Some info about the fault would be helpful?
Whats the drives history?
Was it dropped?
Was Smartware password set?
Plus uploading some high quality pictures of both sides of the PCB
The more info you give the better responses you will get.
Loki
PostPosted: October 12th, 2012, 9:02
This drive offers the same four connection points as others in the BMVV Passport series.
But as Loki pointed out, the recover strategy depends upon the failure . . .
http://www.datasaversllc.com
PostPosted: October 12th, 2012, 9:05
Touche! :D
Drive has not been dropped, it spins and makes no un-normal noice.
The "WD Smartware" partition gets mounted and everything seems to be there. I can even launch the installer and unlock.exe. Unlock.exe reports that drive is not locked. The SmartWare GUI is extremely slow and does not recognize the drive.
The data partition appears but is not accesible, when trying to access it the drive starts seeking (led starts blinking).
My best guess is that there are some kind of sector damage and drive needs imaging.
All connectors has been cleaned with teslanol and micro-usb has been measured to ensure connectivity with PCB.
PostPosted: October 12th, 2012, 9:16
Pictures
PostPosted: October 12th, 2012, 10:04
All of this stuff has been posted before on this forum. Here is one such post . . . read it all of the way through, because Terranova noted I made a mistake.
what-doing-wrong-t18160.html?hilit=usb%20to%20sata%20E71#p121616
The search engine is your friend . . .
PostPosted: October 12th, 2012, 11:40
I'm assuming you know how to connect this drive up via COM port to your PC3K?
Have you done any other tests yet? ie backed up the SA modules & ROM, SA module tests etc
Just for info as you asked about the SATA hack connections.
Remove Capacitors: C13, C18, C31 & C33
Soldering points are E71, E72, E73, E74
Using the Search on this forum will help you find what to solder & where :wink: You'll learn more this way
Loki
PostPosted: October 15th, 2012, 7:09
Yianni,
They cant read this thread.
PostPosted: October 15th, 2012, 15:05
Malista!
May seenhoritay & efharisto polee!
Jon
PostPosted: October 16th, 2012, 3:21
:mrgreen: :lol:
PostPosted: October 16th, 2012, 9:32
This is first step. I would like to see the output from OP's drive
PostPosted: October 18th, 2012, 8:45
It actually was a head issue. Changed HSA and now functioning. Wonder if this could be because one of the heads had write issues. Could it be possible that smartware stores information on user partition when initializing? Otherwise i have no explanation why smartware partition would function but not user partition and head change solved the problem. :?:
PostPosted: June 23rd, 2015, 3:06
Hello to all.
Sorry for the forum necromancy, but I just registered and still I cannot access this link.
Is it because I haven't posted enough posts yet or some other kind of authorization is needed?
PostPosted: June 23rd, 2015, 15:08
I think it's just a bad link. Probably just out of date. What info are you looking for?
If you're looking for USB > SATA compatibility, then you should go here: https://www.data-medics.com/forum/viewt ... ?f=25&t=13
PostPosted: June 24th, 2015, 3:03
It's not bad link.
Its linking to a part of the forum that is not publicly available.
Users browsing this forum: No registered users and 73 guests
