 Post subject: LDR for WD3200BEVT needed
PostPosted: September 28th, 2012, 3:55
LDR for WD3200BEVT
22CT0
DCM: DACVJBBB
Thank you in advance!
 Post subject: Re: LDR for WD3200BEVT needed
PostPosted: September 28th, 2012, 6:20
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 128
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 03.28C
ROM generation.......................... : 03.28C
Link table version...................... : 01.0K.
Consolidated ROM version................ : 00030028
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 00030028
PostPosted: October 8th, 2012, 10:14
look here
http://files.hddguru.com/download/PC-30 ... ty/Denali/
PostPosted: October 15th, 2012, 4:02
Thanks for the hint. Actually I've explored through those.
Problem solved, data recovered and case closed.
Users browsing this forum: No registered users and 75 guests
