 Post subject: Wanted: PCB for Fujitsu MHT2060AT
PostPosted: October 16th, 2012, 23:02
I have an external Fujitsu hard drive which stopped working/spinning recently, it may have been a surge but I don't really know. Could you please suggest a solution to retrieve the data?
The information for the drive/PCB is as follows:
Brand Fujitsu
Model MHT2060AT
Part No. CA06297-B306
Sr. No. NN59T4A18ACY
Date 2004-10
Firmware No. 07C5-0022
Rev. No. A [double line over 0 1 2] 3 4 5 6 7 8 9
PCB No. CA26325-B17204BA
thank you for any help
 Post subject: Re: Wanted: PCB for Fujitsu MHT2060AT
PostPosted: October 16th, 2012, 23:18
Address the issue by fixing if possible or replacing.
All info needed to do this on your own exists on the forum. Use the search function.
PostPosted: October 17th, 2012, 15:12
labtech
replacing the board is probably the simplest thing to do, finding a matching board is more difficult, could you suggest any link
thanks
PostPosted: October 17th, 2012, 19:01
https://www.facebook.com/media/set/?set ... 584&type=3
http://www.donordrives.com/hard-drive-p ... swap-match
PostPosted: October 23rd, 2012, 5:44
I have this PCB. Contact me for more details.
Users browsing this forum: Google [Bot] and 90 guests
