 Post subject: Seagate Barracuda 7200.10 250 Gb ST350310AS not detecting!!
PostPosted: October 12th, 2012, 22:31
I have a desktop pc core i3 with Intel DH61WW it was just working fine.This morning when I switched on,Windows freezed for a long time so I switched off my ups and restarted,Windows again freezed.This time when I switched off my ups my pc still running,I don't know what malfunction in my ups,But this time hard disk is not recognized by bios and as well as windows.I tried changing cables but no uses.I also tried in my friend's pc but the result is same.One thing happened in my friend's pc,I went In device manager and had a scan for hard ware changes.my HDD appeared for a while and appeared a message to format it and then disappeared.I have a lot of data on this.Please help me !!!
 Post subject: Re: Seagate Barracuda 7200.10 250 Gb ST350310AS not detectin
PostPosted: October 13th, 2012, 0:53
Hard disk is deteriorating, bad sectors and likely a firmware problem. If you want to confirm this, search "terminal" and post output here once powering drive on.
Do not format if data is important.
PostPosted: October 13th, 2012, 7:00
I didn't get you ,terminal means
I examined the drive is spinning,
I want to say one more thing I tried seatools dos but no use...
please help me
PostPosted: October 13th, 2012, 9:11
Use the search function
PostPosted: October 13th, 2012, 9:25
where to use search? in this forum or in my hdd?
PostPosted: October 13th, 2012, 9:32
thank you labtech
could you please tell me the procedure to search terminal
PostPosted: October 13th, 2012, 13:49
you need to make this.
http://hddguru.com/articles/2005.10.01- ... schematic/
Use Hyperterminal and post the output
Get some help if you can't do it yourself.
google around, all these information is easily available .
But if your data is important, think if you want to do it yourself or take pro help.
PostPosted: October 14th, 2012, 5:07
you mean I have to connect rs232 to my hdd and perform some tests??
sir yesterday I again tried seatools Dos it some times detecting hdd but unable to perform short test as well as long tests....
PostPosted: October 14th, 2012, 8:03
Yes. But for now don't send any commands. Just capture HDD startup messages. Separate power supply for HDD is handy.
PostPosted: October 15th, 2012, 15:36
please any one post the link of complete tutorial....
PostPosted: October 15th, 2012, 20:02
Here it is: http://www.elektroda.pl/rtvforum/topic872300.html
PostPosted: October 16th, 2012, 4:31
thank u SAjunky
but I need in English,..,...
PostPosted: October 16th, 2012, 4:47
The "search" function on the Forum, Google is easy to use as well. Here are 2 links about the TTL serial connection this is NOT a normal rs232 signal level so don't use normal serial port level pins you need the TTL level signals described below.
http://www.amazon.com/PL2303HX-RS232-Ca ... +usb+rs232
Here is info about where to connect cables to the drive
https://sites.google.com/site/seagatefix/
PostPosted: October 17th, 2012, 3:22
Thank you Networks
Users browsing this forum: Google [Bot] and 169 guests
