 Post subject: problem description and solution way toshiba MK5065GSXN
PostPosted: October 22nd, 2012, 15:50
I have toshiba laptop with mk5065gsxn hdd2j12 b ul01 s 500gb sata hdd in it. the laptop was drop my hand and then hdd gives an error. bios can't recognize it and when i turn on the device hdd gives a tock tock sound in it. When i open the cover of the hdd the plates are spins ok. but the reader arms goes to the center then goes to the stop position and it goes to the middle point of the heads and turns back to the stopping position and repeat this positions.
for the solution i replace the hdd controller pcb with a correct and ok one but it gives same problem to me. can you show and answer to me for rescue the files from this hdd.
 Post subject: Re: problem description and solution way toshiba MK5065GSXN
PostPosted: October 22nd, 2012, 16:12
kazimates wrote:
the laptop was drop
:shock: IMHO this is not a DIY situation (especially not after these repair attempts). There is likely to be internal damage. I see no alternative to using the services of a professional DR company, if the data is important to you - unfortunately the repair attempts so far have probably reduced the liklihood of success.
PostPosted: October 22nd, 2012, 16:51
Replacing the PCB is useless, you have contaminated the disk (the latest problem) and there will be likely media damage beside killed heads.
So now it is better to say "if data WAS important" ...
Note : where the idea about changing the PCB came from ? In retrospective I should sell parts instead of drives....
PostPosted: October 23rd, 2012, 6:01
The PCB myth is STILL too hard to die...
PostPosted: October 23rd, 2012, 6:24
Just like the freezer myth
Loki
PostPosted: October 23rd, 2012, 8:47
Freezer is not a myth, it is based on quantum theory. Read about physics, study noise characteristics of amplifiers, you will see it has scientific explanation. It is not I do recommend it. Fact it is dangerous, works for few minutes only (not enough to backup data), but just enough to load and initialise firmware, which could be loaded from external source in the perfectly safe way.
PostPosted: October 23rd, 2012, 9:38
On older drives it sometimes worked but on modern drives?
I had just written a whole section about how atoms expand & contract due to heat & cold etc but then decided lifes to short to argue & I really cant be bothered
Loki
PostPosted: October 23rd, 2012, 10:10
Sure, freezer is not a myth if you intend to eat the drive at a later time.
On any other case, :mrgreen:
PostPosted: October 23rd, 2012, 15:07
i had a hulk that would image only frozen... So no , not a myth. But highly situational.
PostPosted: October 23rd, 2012, 17:32
Not exactly frozen : something ON THE DRIVE worked only at low temperature. This doesn't change the fact that the "freezer" thing is bull... ehm, a myth.
PostPosted: October 24th, 2012, 3:08
Exactly so.
Users browsing this forum: No registered users and 239 guests
