 Post subject: ST500DM002 - heads problem?
PostPosted: October 24th, 2012, 17:27
Another Seagate in the lab.
Terminal output:
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
[00131FDF]v00000008q[00132095]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008q[001320DA]v00000008qv00000008qv00000008qv00000008q
InitiateMarkPendingReallocateRequest for disc_lba: 00132DE5!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DE6!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DE7!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DE8!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DE9!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DEA!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DEB!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DEC!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DED!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DEE!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DEF!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DF0!
InitiateMarkPendingReallocateRequest for disc_lba: 00132DF1!
Can't read ID, get DRD, DSC after 10 sec. I have access to terminal.
Heads or SA problem?
Any hints will be helpful.
 Post subject: Re: ST500DM002 - heads problem?
PostPosted: October 25th, 2012, 1:47
Can be both (weak head) or fw.
PostPosted: October 25th, 2012, 3:25
If problem is with FW how to check/solve it?
PostPosted: October 26th, 2012, 16:57
Patient heads work perfect in donor. So problem is with SA. Probably bad blocks in SA.
Friends, do you have way to deal with that?
PostPosted: October 26th, 2012, 16:59
What platform do you have ? (SD, PC3000, etc.) ?
PostPosted: October 26th, 2012, 17:32
PC3000.
PostPosted: October 28th, 2012, 11:55
What's the terminal log after head swap? The same?
ACELab partner
PostPosted: October 28th, 2012, 17:31
I check only patient heads in donor. Works perfect, so I exclude problem with patent heads.
Users browsing this forum: Bing [Bot] and 60 guests
