 Post subject: wd1600js 22mhb0 firmware
PostPosted: October 5th, 2012, 3:02
Please , I need firmware for wd1600js 22mhb0
 Post subject: Re: wd1600js 22mhb0 firmware
PostPosted: October 5th, 2012, 9:52
Any particular part of the firmware or all of it?
What version?
What fw tool are you using?
PostPosted: October 29th, 2012, 6:53
Sorry , back online
mdl : wd1600js 22mhb0
date : 18 jan 2006
dcm : HSCACT2AH
I desolder 25P10VP chip and I use a programmer
PostPosted: October 29th, 2012, 8:06
What is wrong with the drive?
What are you trying to accomplish?
PostPosted: October 29th, 2012, 8:46
HDD is not recognized, no motor noise (almost dead)
Whit another PCB (wd1600js) but whit anoher model , hdd is power up, but is not recognized correctly. I desolder
PostPosted: October 29th, 2012, 13:07
Ok, so that's good, but have to make sure the PCBs are compatible. Check the codes.
PostPosted: October 30th, 2012, 8:29
I desolder 25P10VP chip from second PCB. Whit new chip , HDD turn on , but is not recognized correctly . I think if I have good firmware for wd1600js 22mhb0 is possible to solve problem
PostPosted: October 30th, 2012, 9:10
No, that's not how it works. The 25P... chip from the bad PCB should be soldered to the second PCB, again as long as their compatible.
PostPosted: October 31st, 2012, 9:31
I desolder just for test. PCB1=PCB2 , but software from 25P10VP from PCB1 <> software from PCB2.
In first post I say : "Please , I need firmware for wd1600js 22mhb0". So , I`m searching for this firmware
Users browsing this forum: Google [Bot] and 235 guests
