Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Replacing Pcb Samsung HD204UI
PostPosted: November 1st, 2012, 11:59
Yes that´s what I got when using the diode setting on my multimeter.
I will check your other suggestions.
I think I will but another board, but I don´t think I will be able to replace the chip.
I will get back with more information in a couple of days. Thanks to everyone.
PostPosted: November 1st, 2012, 16:12
Your local TV/AV repair shop should be able to swap the chip.
PostPosted: November 4th, 2012, 10:36
I found out the drive is still in warranty so I ordered a PCB from DriveStore.biz.
When I get it I will see if replacing the board revives the disc.
If not I will have to decide if I go for the warranty or attempt to repair the board with your help.
In the meantime, thanks a lot for your help
Ritual
PostPosted: January 23rd, 2018, 5:08
Hi guys.
Thank you, I did exactly what you mention in this post and it worked. I removed the Diode and shortenend the 0 ohm resistor.
Users browsing this forum: No registered users and 45 guests
