 Post subject: why does hdd fall to freeze state??
PostPosted: November 1st, 2012, 22:33
Hello, I'm a new member. I hope receive much care from friends in this forum!
I have a question. Why does hdd fall to freeze state?
Thanks so much!
 Post subject: Re: why does hdd fall to freeze state??
PostPosted: November 1st, 2012, 22:43
Full hdd model?
PostPosted: November 1st, 2012, 23:13
Hard drives fall to a freeze state when someone leaves it in the freezer too long. This can also lead to freezer burn. And with freezer burn comes data loss. :wink:
PostPosted: November 2nd, 2012, 12:28
HDD seagate model ST3160815AS s/n 5RA8ZKNR
PostPosted: November 3rd, 2012, 20:31
Most likely the drive has gotten to the point where it has several issues:
1. Bad sectors
2. High chance of firmware issue
3. Possible failing/failed read-write components
Need a solid diagnostic by a professional to narrow down to the exact issues.
I am afraid that DIY is not possible as like you said the drive freezes.
Also, this is contingent on the fact that you are not actually referring to the drive being physically dropped in a manner that sustained a major shock. In that case, there is definitely a spindle mechanical issue possibility.
PostPosted: November 6th, 2012, 12:52
thanks for helps!!
After login to windows Part D of my hdd that be sudden to hide. I used to hien boot to check for problem and i known my hdd have been freeze :((. i unknow the special cable to connect to hdd? has everyone got any special cable? can i give me some photo about it.. thanks so much
PostPosted: November 6th, 2012, 13:10
A cable will not help in any way.
There are other problems that a cable can't address. It's internal problem.
