 Post subject: how to unlock seagate ST3120026A in max security mode (nopw)
PostPosted: January 16th, 2010, 8:21
How to unlock ST3120026A when it's in maximum security and the master password is lost
I tested generics ones “Seagate[ ]*” and others but it just failed”…
I dont care of the data on it ...
Can this disk unlocked for free ?
by software (using ATA commands ) ?
by hardware (max232 / serial ) ?
Finally I use GNU/Linux , can hdparm be used to brute force the disk ?
http://rzr.online.fr/q/ata
Please (free) help :
http://rzr.online.fr/q/hdd#
how to unlock/format ST3120026A in max security ?
"ALPINE - 1_Disk M.14 01-16-03 11:51"
 Post subject: Re: how to unlock seagate ST3120026A in max security mode (nopw)
PostPosted: January 18th, 2010, 19:55
RZR, have a look at command F3. Also, please stop dredging up old posts. The best advice I can give you is to prove you are trying and most people here will guide you in your learning. No one will give you the answers outright.
Shawn
PostPosted: January 19th, 2010, 3:46
Hint 1: Use rs232/ttl convertor
Hint 2: There's a list of seagate commands somewhere in this forum
Hint 3: Someone posted a solution for another seagate model that need only minor adaptation
PostPosted: October 7th, 2012, 17:27
I guess hint #3 is ...
T>/2 (Enter)
2>S006b (Enter)
2>R21,01 (Enter)
2>C0,570 (Enter)
2>W20,01 (Enter)
can anyone translate this to english ? is S006b related to geometry ?
how-unlock-seagate-st380012ace-t14488.html
PostPosted: October 8th, 2012, 9:45
I think start from hint #1.
Post terminal boot messages, in this way family and firmware version can be identified.
BTW, Sxxxx is a command seek to cylinder. On your drive this solution won't work.
PostPosted: November 3rd, 2012, 7:07
About #1 I thought about using LVTTL UART of my raspberry pi , but I am unsure if it is safe , since I've been reading that hdd is powered by 5V , not 3.3V ...
I am Invesitigating ...
PostPosted: August 2nd, 2014, 13:43
More data as requested :
4096k x 16 buffer detected
Buzz  - Head Mask 0000 - Switch to full int.
              Spin Ready
3.06  10-21-03 15:53
(P)PATA Reset
Slave
How to get the cyl offset from SA sectors ?
Users browsing this forum: No registered users and 725 guests
