Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Samsung HM100UI / UZ4 not spinning
PostPosted: November 4th, 2012, 13:28
Hi Everyone,
It seems couple people have had this issue before. MY Samsung HM100UI/UZ4 is not spinning. it was part of an external hard drive. I've opened it up to test it as internal hdd but did not work either.
here are some pics. there is an obvious burn out at the PCB connector and i probably should replace the PCB. however if you look at it and let me know if thats gona fix.
Axar
 Post subject: Re: Samsung HM100UI / UZ4 not spinning
PostPosted: November 4th, 2012, 15:14
Doesn't look like a "burn" at the PCB connection, just a little corroded.
Was this drive made about October 2010 by any chance?
PostPosted: November 4th, 2012, 15:29
Yes, You are right. IS that a bad thing? :(
PostPosted: November 4th, 2012, 16:12
The date code on the sticker on the underside of the PCB appears to be "20101015" which would suggest October 15, 2010.
Also, the date codes on the SDRAM and MCU are 1028 and 1036, ie weeks 28 and 36 of 2010.
PostPosted: November 4th, 2012, 16:18
axar wrote:
Hi Everyone,
If you put your ear against the cover, can you hear the drive trying to spin up? If so, then you may have a stiction fault or a seized spindle bearing.
As for the "burn" marks, you can shine them up with a soft white pencil eraser. Just don't rub too hard.
PostPosted: November 4th, 2012, 16:20
Well spotted!
There does appear to be a bad batch of these drives from around that date, which we suspect that the actual ROM chip appears to degrade and/or corrupt.
If you check the startup messages via a serial terminal connection, it will display a message similar to "ROM unpack failure" and the drive will not spin up.
We have a solution to this, but it requires specialist tools and knowledge to implement.
PostPosted: November 4th, 2012, 18:02
thanks for the reply guys.
The hard drive makes no attempt to turn on. Dead quiet. It is October 2010 drive. Are there any diagnostic methods i can perform to find out?
I can connect my hdd to a computer through usb. Can i perform any diagnostics there?
PostPosted: November 4th, 2012, 18:37
I can help you measure the onboard power supplies. If you don't have a digital multimeter, you could obtain one for about US$5.
There are two 4R7 coils near the TLS2505 motor controller IC. Measure their voltages. You could use the PCB screw holes as your ground reference.
These voltages will be the Vcore and Vio supplies for the Marvell MCU and SDRAM and Winbond flash memory. According to the SDRAM datasheet, the Vio supply will probably be +2.5V. I suspect that Vcore would be around +1.2V.
M13S2561616A-5T, ESMT, DDR SDRAM, 64Mbit, 1M x 16 Bit x 4 Banks, 2.5V, 200MHz:
http://www.esmt.com.tw/DB/manager/upload/M13S64164A.pdf
If these voltages are OK, then you will probably need a PCB adaptation service. I could try to help you obtain a report from the serial console if you get this far. This would help to confirm pcimage's diagnosis.
PostPosted: November 4th, 2012, 19:13
pcimage wrote:
Well spotted!
I second that
PostPosted: November 5th, 2012, 18:14
Unfortunately yes, it's a bad thing (for you)
A new PCB will not help you in this particular case. Even with "ROM adaptation", because it is almost certainly the actual ROM that has failed, not the PCB itself.
This can be confirmed by a terminal output.
PostPosted: November 5th, 2012, 19:34
Great News!
I was able to see my hard drive as usb in my mac. however, it didnt recognize as a hard drive. Not even in disk util
http://imageshack.us/a/img197/9527/ego2.png
http://imageshack.us/a/img72/2861/ego1h.png
PostPosted: November 5th, 2012, 19:46
i was able to detect the usb but not hdd in my mac. is there a way to diagnose it from here?
PostPosted: November 5th, 2012, 21:32
A "ROM adaptation" is not the same as a "PCB adaptation".
PCB Repair & Firmware Adaptation Services:
http://www.donordrives.com/services
"Donor Drives offers its customers FREE PCB Services, whether it is a firmware chip swap or adaptation service. These services are often required, when a hard disk drive has experienced a circuit board failure, and simply replacing a faulty circuit board is not making hard drive operational. That happens due to uniqueness of the circuit board ...
Once we receive your hard drive, we will diagnose and identify the exact failure. If repair is possible, you will only be billed for shipping back to you.
In case where a hard drive cannot be fixed (mechanical damage, stuck spindle, bad sectors, firmware bug, etc.) with your permission, we may suggest to forward your hard drive to a data recovery service provider ..."
This suggests to me that, if axar's PCB is repairable or replaceable, then this would be done for the cost of the PCB plus postage. In any case, the fact that the HDD is required would suggest that the ROM might be rebuilt from the SA of the original HDD. A typical example would be WD ROYL drives.
PostPosted: November 6th, 2012, 5:17
OK fine. Let him go for it.
I shall leave you to it.
Good luck :-)
PostPosted: November 6th, 2012, 5:41
The problem is ROM, which in effect is basically firmware on the PCB. PCimage is right, seen this many times and no amount of PCB or ROM adaption will be any use.
PostPosted: November 6th, 2012, 6:41
this is getting REALLY annoying.
PostPosted: November 6th, 2012, 8:48
+1 :good:
PostPosted: November 6th, 2012, 13:44
Thanks for the reply everyone.
It seems the only choice is to take it to a specialist. However, I would like to know your honest opinion on how much would this cost. It's matter of is the data worth spending 500$ on it; Probably not. Does the data worth about 100$, Yes.
There are many out there with insane costs for recovery and i don't think the data is worth that much. I'm thinking of making a run to the near by recovery guys to see how much they will charge. I Was wondering if you guys point me out on how much should it cost to recover this. There is only about 300Gb max worth of data of which 200Gb is garbage, only about 100Gb maybe worth recovering.
Also maybe something that i can do on my own for low cost worth equipment. Do share.
Thanks again for your input.
p.s. Currency in Canadian dollars.
PostPosted: November 6th, 2012, 13:53
Hi axar, contact lcoughey.
PostPosted: November 7th, 2012, 7:20
+1 for lcoughey. You can get your drive evaluated and then decide if it's worth the $ required.
Users browsing this forum: Google [Bot] and 240 guests
