 Post subject: PCB Western Digital 500
PostPosted: November 4th, 2012, 20:42
Hi
I need a pcb for my WD 5000AAVS-00ZTB0
PCB sticker :2061-701444-JOO-AB
The power is gone because use of wrong power supply,so the disc wont spin .
Anyone have any idea where to find a replacement pcb ? Ore how to fix the pcb ? Someone that might be able to fix it ?
Have tried e-bay and a lot of other sites on the net , but no luck at all .
Hate to let all the data on my disc go down the drain .
vance
 Post subject: Re: PCB Western Digital 500
PostPosted: November 4th, 2012, 21:02
You may be able to fix it.
See http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
... and http://www.users.on.net/~fzabkar/HDD/bi ... diodes.jpg
Sometimes the SMOOTH motor controller is damaged by the overvoltage, especially if the resistors are open circuit. In this case, if location U12 is vacant, then you'll need a PCB adaptation service.
Let us know what you find.
PostPosted: November 4th, 2012, 22:34
Thanks for helping fzabkar !!! :)
If my measurement is right I have a damaged D4 TVS diode (12 v )
Any idea where to get it replaced ? ore to get a new diode , might try to fix it myself if that is my last chance.
Have done some repair before , but not a pro .
Thanks a lot for all info, I am learning , and are happy for all the help I can get.
Vance
PostPosted: November 4th, 2012, 22:43
The TVS diodes are for protecting the pcb from Voltage outages , and not necessary for the functioning of the pcb.
If you have a stable and good power supply, then you can remove the TVS diodes and power on the Drive.
PostPosted: November 4th, 2012, 23:05
Hi
Thanks ..
Ok might try that as a final solution :)
Vance
PostPosted: November 5th, 2012, 14:44
Your question is answered in my FAQ.
Did you measure R64? If it is open circuit, then be prepared for damage to the SMOOTH chip.
PostPosted: November 5th, 2012, 16:18
Hi , yes fzabekar i noticed that after I had posted my question .
I have not measured the R64, i will do so when home from work . Have not done anything yet , just wanted to read more and get more info , before I do anything that might damage the hdd more then necessary. I will try to find someone that might repair it for me .
Thanks for all info ..appreciate it :)
Vance
PostPosted: November 12th, 2012, 20:53
Finally after many e-mails to several workshops (did not get any response ore answer from any of them ) i had to try to fix it myself , I removed the 12v Tvs diode ,and now the disk is spinning again and I can access my data :D
Thanks Fzabkar for the helpful links and tip , and to all you others for comments .
Vance
Users browsing this forum: Google [Bot], WebClaw and 269 guests
