 Post subject: Recovery of 7200.12 drive
PostPosted: November 9th, 2012, 9:21
Is it possible to recover 7200.12 drive with faulty ROM chip and no backup? Only ROM chip is bad, otherwise PCB is working fine when tested on donor drive with donor ROM chip swapped.
 Post subject: Re: Recovery of 7200.12 drive
PostPosted: November 9th, 2012, 9:29
PCB working with another drive's ROM confirms that the PCB is good, but does not confirm that the ROM is bad. What kind of tools do you have for diagnosing the drive? What are the symptoms of the drive? Do you have any terminal output from the drive for us to review?
PostPosted: November 10th, 2012, 5:18
When drive connected with original original PCB with ROM chip, Spindle motor does not start and when I replace ROM from donor PCB of Seagate drive , spindle starts . This clearly shows that ROM chip is short.In that case there could not be any terminal message.
PostPosted: November 13th, 2012, 2:28
more likely the smooth chip is at fault
swap it over and it should work again
PostPosted: November 14th, 2012, 5:31
My friend, please read this carefully. I have written That when I replace ROM chip , PCB starts working, Then how the smooth can be bad.
PostPosted: November 28th, 2012, 19:32
Did u try to place rom into a soic8 reader? playing with settings of latency to try to read it?
PostPosted: November 29th, 2012, 5:57
Yep, my advice first of all is to read ROM in a programmer and check it.
Users browsing this forum: No registered users and 123 guests
